Kohler CH 20 Running Super Rich ?
/ Kohler CH 20 Running Super Rich ? #1
GTSRider
Cub Cadet 3000
Here's a quick background of what I 've done to this Keihin carb on a
CH20 engine with 550 hrs.
New fuel filter
New Fuel pump
New carb rebuild kit with new O-rings and gaskets
New Air Filter assembly
New Spark plugs
Engine running Super Rich....only thing I can think of is float level is off
Anyone know proper Float level adjustment ?
Seems like way too much fuel in bowl...about 1/2' from top.
Tempted to put on new carb.... but I must do a compression check first...
Are vales in these engines hydraulic ?
If not I think the valves may be tight....
Just can't believe the problems with this thing.....last season ran 100+ hrs.
incident free....this year daily problems.
I also need to install a new crank seal...tractor is one greasy mess.
Thanks for reading,
Pete
/ Kohler CH 20 Running Super Rich ? #2
Here's the Keihin float level adjustment info from the Kohler service manual.
I uploaded the complete manual here.
Command_18-26hp_horz_oper.pdf
Thanks...interesting what they say about replacing float, if spec is off...
I've never heard of such a thing.... what say you ?
Pete
Compression in right cylinder is around 160.... 180 lbs. left, according to
Snap On compression gauge...so I think engine internals are ok.....
maybe a little weak on right...but good enough.
So now I am shopping for a new Keihin carb.
I've done everything to this one and engine barely runs other than full
throttle..... and runs like a soot machine with black smoke out
exhaust pipe.
Now that I have decided on a new carb..... my engine is a 2003 model...
but my question is... is there a better more updated carb to go with....
rather than put on the same carb that was on there ?
Pete
/ Kohler CH 20 Running Super Rich ? #7
You are sure that the choke is opening fully after you put it back together the last time.
Positive..... I 'm so careful at this point... I clean air filter once a week....
and it only has about 15 hrs. on it from new.
Funny thing is ... engine ran lean from around June to end of July....
and would not run without 1/3rd choke.
then it started running rich....super rich !
I've cleaned carb so many times I lost count.... and installed a rebuild kit....
I'm finally at the end with this carb and will order a new one.... but it better
not have the same results with the new carb.... I mean could it be ignition ?
I don't think so , because it runs fairly strong at full throttle although not clean.
I was mowing a very thick lawn this morning, so thick it was caking out
" bricks " ,and engine never lost rpm.... and compression check says cylinders are ok.... so by process of elimination.... it must be carb.... sunk $120
in new solenoid... and $50 in rebuild kit...**** ...that's most of a new carb right there !
Hey thanks Man !
That is a great price... I think I am going to go with it.
Ordered new carb thanks to Old Machinest.... and from pictures ... it has a
linkage assembly on right side opposite choke and cable connections....
could this carb have a pump on it ?
Pete
Ok.... I know why motorcycles need an accelerator pump....
but a garden tractor ?
Ok...latest up-dates....
yesterday, I installed new crank seal to stop oily mess all over front of engine and mower deck....took like 3 hr.s to do job , and 2 hrs. to clean messy greasy tractor. Engine is bone dry now....but still runs like crap from super rich
mixture.
Today I installed new Keihin carb ,with fuel accelerator pump, and bigger throat from ebay.... (thanks to Old Machinest )
After 10 -15 minutes or so of trying to get engine to run for more than
2- 3 seconds, I gave up in discusst and went to have a beer with my buddy and get his input. He said I got a bad carb off ebay.
Left there, in a state of depression... and went home , and cranked engine...
ran for like 4 seconds with choke on. Kept playing with it , and got it to run for about 5 seconds tops ..... gave up again , and decided to shower up, and call it quits. Picked up any tools , and put them away.
As I was walking away from tractor , I , for some reason, I decided to give it one more try, I forgot that I had thrown a t-shirt over the carb for the night ,
to keep any debris out of it. I turned starter over , and engine ran
fine for about a minute.. then stalled...when I remembered t-shirt.
Pulled t-shirt off of top of carb , and tried again...this time engine purred like a new re-built engine. So what happened ?
I have a theory that bone dry carb, took that long to fill from fuel pump...BTW fuel pump is new with about 25 hr.s on it now....
Or was there a piece of dust in carb that broke free ?
Don't know , but fine now...of course real test is a 3 hr. mowing
This problem has been going on since May, and has been making me crazy.
First post will tell you what I replaced.
Thanks to Old Machinest and others for your input.
Pete
One last carb question... there is a very fine spring on the throttle linkage rod,
to this Kohler CH 20..... it broke when removing it.
Dealer did not have one in stock ...so ordered a new one.
Now it seems it is unnecessary, as it seems to run fine without it.
I already ordered spring and will get new one next week.... but what is this very fine small spring for ? I can't figure out what it's purpose is ?
/ Kohler CH 20 Running Super Rich ? #16
The spring is just to keep pressure on the governor linkage. Without it the rpm's may surge up and down some.
Ok..thanks... I have it coming in on order and will use it.
I have 2 brand new Kohler crank seals....some how ordered wrong part #
They are new in Kolher bag. If you want them I will send them to you...no use to me.
Part # 24 032 19-S about 1.25 inch inner diameter, so must be for a
smaller engine.
Pete
/ Kohler CH 20 Running Super Rich ? #18
I think that's the seal for the flywheel end of the crank. You may want to hang on to them if it is.
Hmmm.... good point....thanks for alerting my mind....
I'll go on parts piche and look up #.
Thanks again !
Pete
