Kohler CH 20 Running Super Rich ?
   / Kohler CH 20 Running Super Rich ? #1
GTSRider
Cub Cadet 3000
Here's a quick background of what I 've done to this Keihin carb on a
CH20 engine with 550 hrs.
New fuel filter
New Fuel pump
New carb rebuild kit with new O-rings and gaskets
New Air Filter assembly
New Spark plugs
Engine running Super Rich....only thing I can think of is float level is off
Anyone know proper Float level adjustment ?
Seems like way too much fuel in bowl...about 1/2' from top.
Tempted to put on new carb.... but I must do a compression check first...
Are vales in these engines hydraulic ?
If not I think the valves may be tight....
Just can't believe the problems with this thing.....last season ran 100+ hrs.
incident free....this year daily problems.
I also need to install a new crank seal...tractor is one greasy mess.
Thanks for reading,
Pete
   / Kohler CH 20 Running Super Rich ? #2
Here's the Keihin float level adjustment info from the Kohler service manual.
I uploaded the complete manual here.
Command_18-26hp_horz_oper.pdf
Thanks...interesting what they say about replacing float, if spec is off...
I've never heard of such a thing.... what say you ?
Pete
Compression in right cylinder is around 160.... 180 lbs. left, according to
Snap On compression gauge...so I think engine internals are ok.....
maybe a little weak on right...but good enough.
So now I am shopping for a new Keihin carb.
I've done everything to this one and engine barely runs other than full
throttle..... and runs like a soot machine with black smoke out
exhaust pipe.
Now that I have decided on a new carb..... my engine is a 2003 model...
but my question is... is there a better more updated carb to go with....
rather than put on the same carb that was on there ?
Pete
   / Kohler CH 20 Running Super Rich ? #7
You are sure that the choke is opening fully after you put it back together the last time.
Positive..... I 'm so careful at this point... I clean air filter once a week....
and it only has about 15 hrs. on it from new.
Funny thing is ... engine ran lean from around June to end of July....
and would not run without 1/3rd choke.
then it started running rich....super rich !
I've cleaned carb so many times I lost count.... and installed a rebuild kit....
I'm finally at the end with this carb and will order a new one.... but it better
not have the same results with the new carb.... I mean could it be ignition ?
I don't think so , because it runs fairly strong at full throttle although not clean.
I was mowing a very thick lawn this morning, so thick it was caking out
" bricks " ,and engine never lost rpm.... and compression check says cylinders are ok.... so by process of elimination.... it must be carb.... sunk $120
in new solenoid... and $50 in rebuild kit...**** ...that's most of a new carb right there !
Hey thanks Man !
That is a great price... I think I am going to go with it.
2020 Kia Soul SUV (A52377)
2020 Kia Soul SUV...
BAUMA LIGHT TX 12 LOT NUMBER 240 (A53084)
BAUMA LIGHT TX 12...
TEST BID LOT (A50775)
2011 Chevrolet Camaro Convertible Coupe (A52377)
2011 Chevrolet...
U56 DIESEL FIRE PUMP (A51406)
U56 DIESEL FIRE...
JOHN DEERE LOT NUMBER 72 (A53084)
JOHN DEERE LOT...
