Kohler CH 20 Running Super Rich ?
   / Kohler CH 20 Running Super Rich ?
Ordered new carb thanks to Old Machinest.... and from pictures ... it has a
linkage assembly on right side opposite choke and cable connections....
could this carb have a pump on it ?
Pete
Ok.... I know why motorcycles need an accelerator pump....
but a garden tractor ?
Ok...latest up-dates....
yesterday, I installed new crank seal to stop oily mess all over front of engine and mower deck....took like 3 hr.s to do job , and 2 hrs. to clean messy greasy tractor. Engine is bone dry now....but still runs like crap from super rich
mixture.
Today I installed new Keihin carb ,with fuel accelerator pump, and bigger throat from ebay.... (thanks to Old Machinest )
After 10 -15 minutes or so of trying to get engine to run for more than
2- 3 seconds, I gave up in discusst and went to have a beer with my buddy and get his input. He said I got a bad carb off ebay.
Left there, in a state of depression... and went home , and cranked engine...
ran for like 4 seconds with choke on. Kept playing with it , and got it to run for about 5 seconds tops ..... gave up again , and decided to shower up, and call it quits. Picked up any tools , and put them away.
As I was walking away from tractor , I , for some reason, I decided to give it one more try, I forgot that I had thrown a t-shirt over the carb for the night ,
to keep any debris out of it. I turned starter over , and engine ran
fine for about a minute.. then stalled...when I remembered t-shirt.
Pulled t-shirt off of top of carb , and tried again...this time engine purred like a new re-built engine. So what happened ?
I have a theory that bone dry carb, took that long to fill from fuel pump...BTW fuel pump is new with about 25 hr.s on it now....
Or was there a piece of dust in carb that broke free ?
Don't know , but fine now...of course real test is a 3 hr. mowing
This problem has been going on since May, and has been making me crazy.
First post will tell you what I replaced.
Thanks to Old Machinest and others for your input.
Pete
One last carb question... there is a very fine spring on the throttle linkage rod,
to this Kohler CH 20..... it broke when removing it.
Dealer did not have one in stock ...so ordered a new one.
Now it seems it is unnecessary, as it seems to run fine without it.
I already ordered spring and will get new one next week.... but what is this very fine small spring for ? I can't figure out what it's purpose is ?
   / Kohler CH 20 Running Super Rich ? #16
The spring is just to keep pressure on the governor linkage. Without it the rpm's may surge up and down some.
Ok..thanks... I have it coming in on order and will use it.
I have 2 brand new Kohler crank seals....some how ordered wrong part #
They are new in Kolher bag. If you want them I will send them to you...no use to me.
Part # 24 032 19-S about 1.25 inch inner diameter, so must be for a
smaller engine.
Pete
   / Kohler CH 20 Running Super Rich ? #18
I think that's the seal for the flywheel end of the crank. You may want to hang on to them if it is.
Hmmm.... good point....thanks for alerting my mind....
I'll go on parts piche and look up #.
Thanks again !
Pete
Rotary SPOA9-200 Automotive Lift (A56857)
Rotary SPOA9-200...
Adams Tender / Magnolia Trailer (A56436)
Adams Tender /...
2008 HINO 26FT NON CDL BOX TRUCK (A59575)
2008 HINO 26FT NON...
THREE POINT ATTACHMENT (A58214)
THREE POINT...
1997 Ford Tandem Dump Truck (A59814)
1997 Ford Tandem...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
