TYM T293 Lost Power After 20 Minutes Run time
   / TYM T293 Lost Power After 20 Minutes Run time #21
My T233 has a Mitsubishi engine. One of the guys on the forum was looking for a new injector line for his T273. He was shocked at the cost. I looked around on line, at parts for the Mitsubishi L3 engines, which were used in everything from air compressors and generators to CAT skidsteers.
I figured out that TYM, and other manufacturers, are just adding a few digits to the Mitsubishi catalog number. And, If you use the part type or name, just start taking numbers off the TYM part number as you search, you start to find the Mitsubishi, CAT, Etc parts for less than they same part as a TYM.
   / TYM T293 Lost Power After 20 Minutes Run time #22
Hi, I am over on Square H
It has been working fine till now. The last time I had the cutter on was 2019 when my brother was cutting the field for me after my accident. No problem then. I did notice that last winter when I was plowing snow it seemed a bit sluggish in the deep stuff. When the cutter spins up it sounds normal and cuts great. I guess I can try disengaging the cuter when it starts to act up and see if the issue is still there.
I'm over off of 344 and 472.... just around the corner!
When it acts up, disengaging the cutter might give you a direction to look. If the load comes off and the tractor comes back up to speed, well you found the problem.... the cutter.
No other odd noises, smells, or smoke?
Ok, did that. RPM slowly came back but dropped when I tried to increase speed. Also, RPM comes back with the cutter engaged and not moving. I will have a new lift pump Friday so we will see what that does.
   / TYM T293 Lost Power After 20 Minutes Run time #24
Since deliveries through Amazon now can take 7 to 10-days: If there is something I need, I go show it to local brick and mortar shops, and ask if they have somethings similar within 15% to 30% in stock, that I can walk out of the store with. I would expect that my local NAPA would have a universal pump in stock.
   / TYM T293 Lost Power After 20 Minutes Run time #25
This past weekend my buddy was brush hogging with his Ls tractor and it started doing the same thing. I asked if the radiator was clean and he said yes, Once we lifted the hood i could see that the oil cooler hydro cooler and radiator were all plugged , I also pulled the air cleaner and it was real bad, Spent some time blowing everything out, then it ran fine after that,
Radiator is clean and filter is clean. I also pulled the air filter out to make sure micky did not set up a home in there. All clean
I get most of my Amazon orders in two days if it is a Prime supplier. This one is not and is coming USPS
The amazon one is a Chinese copy. The original is Korean made. As far as the price, they aren't quite as high from TYM but still outrageous. All the TYM parts from Mahindra are anywhere from 10-100% higher then from TYM. More Information for AUTOBEST 12D . This is the one I've been using when the customer doesn't want the factory one. One thing I would add, if your new pump doesn't come with a strainer. Install an inline fuel filter before the pump. Most of these are setup were they are pulling unfiltered fuel from the tank. Scratch that. Looked in the manual and this one is setup with the filter before the lift pump.
I looked at the Autobest pump. Specs are good but it says for carburetor only. Does anyone even make a diesel with a carb? I didn't think that was possible. Everything I know about a diesel says it is impossible so I figure it was some gas engine description carry over that a very no-technical person was writing. Since this is just a lift pump to get fuel from the tank to the injector pump at 4-7psi it would not matter.
   / TYM T293 Lost Power After 20 Minutes Run time #29
Yeah, I just ignore that part. Obviously someone wrote that up that has never been under the hood on anything lol. Some of the old distillate fuel tractors used a carb with a fuel that was similar to diesel. No fuel pumps and a lot of the time no electrical system on them either though.
I have heard of those. My farther in law when he was a kid back in the 50s stole fuel from a tractor for his car not knowing. Car smoked like a mother until he burnt most of it out and added pure gas. Never did that again.
   / TYM T293 Lost Power After 20 Minutes Run time #31
That could have also been drip gas. Was very low octane but good enough for the old flatheads and very cheap. My grandpa would buy it for $1 or less a drum back then.
He said it was a mix of Diesel and gas. He was at the station trying to figure out why it was smoking so bad when this one old timer came up and asked him about it. He told the story to the guy and he jus laughed. When the owner of the tractor pulled in all hot about someone stealing his fuel saying he will catch them because it will make them smoke. The old timer said to the farmer he just poured some kerosene in the carb of my father in law to do something (Can't Remember exactly what it was) and it will cause these kids to smoke for a bit. Farmer accepted that and drove off. My father in law was a bit of a trouble maker when he was a kid. Four years in the Navy fixed that. He had lots of stories like that.
   / TYM T293 Lost Power After 20 Minutes Run time #33
Oh dang, that's a good one. Just the laugh I needed today. LMAO.
   / TYM T293 Lost Power After 20 Minutes Run time #34
I pulled into Ely, Nevada at about 0230, To get fuel and some coffee. I’m color blind. Pump had five nozzles. White, light green, green, dark green and black. Figuring black was the highest octane of the bunch, I pumped 10.5-gallons into my 13.5 gallon tank. Grabbed coffee and pack of little chocolate donuts, and pointed south. About ten minutes later, the truck started to stumble and loose power. So, I turned around and went back to Ely for the night.
Next morning I figured out my mistake, and I bought three five gallon gas cans, and used the electric fuel pump to drain the tank into them, then added the 1-gallon of reserve gas I carried, and limped ot the gas station. I got it filled up with gasoline, and pointed south again. About half way to Vegas, I saw that one of the Contractors I worked with fairly frequently had their crusher, sett up in a gravel pit. I drove in, and the operator and I dumped the three cans of diesel/gasoline mix into the fuel tank for their big generator set. Talked to the guys for a bit, and went on down the road.
   / TYM T293 Lost Power After 20 Minutes Run time #35
I purged about a quart of fuel from the fuel line and there was no water in what I purged out. So hope that is all there was. I did do the open the fuel cap trick and it actually helped a lot. Took the cap apart and it was a bit dirty and had moisture in the foam inside the cap. Blew out the moisture and cleaned cap. Will see how she runs today. Fuel Tank is now full.
   / TYM T293 Lost Power After 20 Minutes Run time #36
I would think water in the fuel. Maybe low fuel pump pressure to the filter.
Or PTOs is in a bind.? Like driving a car with emergency brake on.
Ok, so here is what I have done. New lift pump added and after 26 minutes it started to bog down again. I disengaged the brush hog and still did the same thing just not as severe. At idle it did seem to be running a bit rough. Almost like a gas engine when you have a spark plug issue and misses. Could it be an injector issue? It is going to take me a long time to mow this field at 20 minutes and then rest for two hours. My wife says to play the Lottery and if I win I can get a new tractor. She is no help.
2018 KENWORTH T680 TANDEM AXLE SLEEPER (A59904)
2018 KENWORTH T680...
2018 JOHN DEERE 323E SKID STEER (A60429)
2018 JOHN DEERE...
WHITE PINE TONGUE & GROOVE (A60432)
WHITE PINE TONGUE...
2017 Toyota Tundra SR5 Ext. Cab Pickup Truck (A59230)
2017 Toyota Tundra...
FUTURE 60" PALLET FORK (A60432)
FUTURE 60" PALLET...
2004 Ford F-150 Ext. Cab Pickup Truck (A59230)
2004 Ford F-150...
