Kioti CK25 head gasket replace.
/ Kioti CK25 head gasket replace. #1
Alan46
Elite Member
Estacada Oregon
KiotiCK25 HST
Hi all, I have a blown head gasket. Just wondering if anyone has replaced one and how much of a job it is? It’s a 2005 CK25 HST with 1300 hrs. IMG_5935.jpeg
/ Kioti CK25 head gasket replace. #2
I replaced it on my CK30, first time I did anything like it. Just took my time, service manual I found here was pretty accurate.
Thanks for the reply. Did you have any head work done and did you find what caused the problem?
/ Kioti CK25 head gasket replace. #4
Head gasket was damaged, don't know the cause. I caught it because it pressurized the cooling system and was spitting coolant out the overflow tube on the reservoir. I had the head machined to ensure if was flat, machine shop said it didn't take much and was otherwise good. The original head gasket was fiber looking and the replacement from the dealer was multi layer metal so I'm hoping the new design is more robust. I'm not a mechanic so might have missed some clues, but it's back together and working fine.
That’s the same problem I have it pressurized the cooling system and was spitting coolant out the overflow tube on the reservoir.
Going to pull the head on Friday
Having a diesel mechanic friend of mine help, or should I say I’ll help him!😂 I’ll post the results good or bad! My friend says it’s a head gasket, cracked block or a cracked head! 🥵
Hey AaronD81, can you send me a link to the manual you have?
I can’t seem to find it!
Thank you. We’re getting ready to start the tear down! Wish us luck that it’s a head gasket!🤞🏻
Good news! It only took my friend 2 hours to get the head off, if was a leaking head gasket! I called a Kioti dealer and they wanted 5 large to do the job, including resurfacing and valve seals,WTF is up with that price?IMG_5965.jpeg
Bush Hog 286 3-Pt Rotary Mower (A66408)
Bush Hog 286 3-Pt...
Kubota L3901HST
Kubota L3901HST
John Deere C450 Mower Conditioner (A66285)
John Deere C450...
2023 PETERBILT 567 (A65643)
2023 PETERBILT 567...
2018 Ford Explorer AWD SUV (A64557)
2018 Ford Explorer...
2025 New 6 Seater Electric Golf Cart (A65579)
2025 New 6 Seater...
