Kioti CK25 head gasket replace.
/ Kioti CK25 head gasket replace. #1
Alan46
Elite Member
Estacada Oregon
KiotiCK25 HST
Hi all, I have a blown head gasket. Just wondering if anyone has replaced one and how much of a job it is? It’s a 2005 CK25 HST with 1300 hrs. IMG_5935.jpeg
/ Kioti CK25 head gasket replace. #2
I replaced it on my CK30, first time I did anything like it. Just took my time, service manual I found here was pretty accurate.
Thanks for the reply. Did you have any head work done and did you find what caused the problem?
/ Kioti CK25 head gasket replace. #4
Head gasket was damaged, don't know the cause. I caught it because it pressurized the cooling system and was spitting coolant out the overflow tube on the reservoir. I had the head machined to ensure if was flat, machine shop said it didn't take much and was otherwise good. The original head gasket was fiber looking and the replacement from the dealer was multi layer metal so I'm hoping the new design is more robust. I'm not a mechanic so might have missed some clues, but it's back together and working fine.
That’s the same problem I have it pressurized the cooling system and was spitting coolant out the overflow tube on the reservoir.
Going to pull the head on Friday
Having a diesel mechanic friend of mine help, or should I say I’ll help him!😂 I’ll post the results good or bad! My friend says it’s a head gasket, cracked block or a cracked head! 🥵
Hey AaronD81, can you send me a link to the manual you have?
I can’t seem to find it!
Thank you. We’re getting ready to start the tear down! Wish us luck that it’s a head gasket!🤞🏻
Good news! It only took my friend 2 hours to get the head off, if was a leaking head gasket! I called a Kioti dealer and they wanted 5 large to do the job, including resurfacing and valve seals,WTF is up with that price?IMG_5965.jpeg
Dual Tailwheel Rhino 284 7ft Cutter 2.5in cut capacity (A63689)
Dual Tailwheel...
2022 EZ-GO ELITE...
2018 CATERPILLAR 232D SKID STEER (A64279)
2018 CATERPILLAR...
Caterpillar 740 Articulated Truck Service Manuals Vol. 1 and Vol. 2 (A63117)
Caterpillar 740...
(INOP) INTERNATIONAL FARMALL 140 TRACTOR (A63291)
(INOP)...
Tooth Bucket Mini Excavator Attachment (A61572)
Tooth Bucket Mini...
