John Deere 4400
/ John Deere 4400 #1
mekongrabbit
Camden, SC
John Deere 4400; New Holland TN65
Sometimes while I was raking hay last week, the hour meter went blank on my John Deere 4400 compact tractor. I would appreciate any advice.
Could it be caused by a blown fuse?
The owner's manual is no help.
/ John Deere 4400 #2
Does your fuel gauge still work? There IS a fuse for the time clock but don't recall which it is...
/ John Deere 4400
All other gauges operate as normal; only the hour meter is out. Have not had time to remove the dash and check the connection or check the fuses.
/ John Deere 4400 #4
Your best hope is the connector contacts are dirty/corroded. If cleaning them does not help, then you need
a new cluster ($$$$), or install a separate hour meter. I did the latter.
1994 CHEVROLET GMT-400 EXTENDED CAB TRUCK (A64280)
1994 CHEVROLET...
F-250 Super Duty 4WD 6.2 (A63689)
F-250 Super Duty...
PALLET FORK MOUNT SAFETY BASKET (A61572)
PALLET FORK MOUNT...
UNUSED 2023 JCB S4550E ELECTRIC SCISSOR LIFT (A65053)
UNUSED 2023 JCB...
60in. Work Bench (A65640)
60in. Work Bench...
20x20 Car Port (A65640)
20x20 Car Port...
