John Deere 4400
/ John Deere 4400 #1
mekongrabbit
Camden, SC
John Deere 4400; New Holland TN65
Sometimes while I was raking hay last week, the hour meter went blank on my John Deere 4400 compact tractor. I would appreciate any advice.
Could it be caused by a blown fuse?
The owner's manual is no help.
/ John Deere 4400 #2
Does your fuel gauge still work? There IS a fuse for the time clock but don't recall which it is...
/ John Deere 4400
All other gauges operate as normal; only the hour meter is out. Have not had time to remove the dash and check the connection or check the fuses.
/ John Deere 4400 #4
Your best hope is the connector contacts are dirty/corroded. If cleaning them does not help, then you need
a new cluster ($$$$), or install a separate hour meter. I did the latter.
2022 EZ-GO ELITE...
2022 EZ-GO ELITE...
2016 JCB 3CX 4x4 Loader Backhoe (A64194)
2016 JCB 3CX 4x4...
PORTER CABLE AIR COMPRESSOR (A65643)
PORTER CABLE AIR...
2017 Nissan Altima Sedan (A64557)
2017 Nissan Altima...
2012 Mack CHU613 Day Cab Truck, VIN # 1M1AN09Y6CM010558 (A65563)
2012 Mack CHU613...
