john deere 1050 joystick installation help!!!!
   / john deere 1050 joystick installation help!!!!
Ok here is how it hooked up now the out on the joystick control valve from the fel is going to the side of the transmission the in is coming from the bottom of he block under the seat the pby one is coming from the top of the same block that the in is coming from but from the top of it. 8514EE9F-B9AD-4D1F-BAA7-2152A0486406.jpeg
Can you send me a pic of your setup please.
   / john deere 1050 joystick installation help!!!! #43
Ok here is how it hooked up now the out on the joystick control valve from the fel is going to the side of the transmission the in is coming from the bottom of he block under the seat the pby one is coming from the top of the same block that the in is coming from but from the top of it. View attachment 543766
Kris
You are, I am afraid, answering my questions backwards.
I need to know where each green line come from not where it goes to..
For example, The green metal line from the pump would have oil coming out the end of it as soon as you started to crank the engine.
You need to do that test of removing the line and directing it into a clean pail as you crank the engine for a few seconds. If a stream of oil comes out you have found the pump output which needs to go to the FEL valve block IN.
For the identification of the return to transmission line, use a funnel and pour the oil from the clean pan that came from the pump discharge line line back into the transmission.
When you had only the 3 pt hitch in the circuit, mark up your photo with just a single line to show me the two lines you connected together.
Am I correct in remembering, the problems with the hydraulics only began when the two single control levers were replaced with the joystick?
Dave M7040
This is where the hard lines come from
Yes sir that is correct. Everything worked prior to this. I done swapped dang hoses every which way but the right way I guess. I’m at a lost
The green line is where I tied both lines together and 3pt hitch worked
   / john deere 1050 joystick installation help!!!! #46
Was the FEL valve removed from the tractor to install the joystick?
Did anyone remove this cap I have circled in yellow?
Dave M7040
They removed the old controller valve that operated the loader the two stick controller.that side port has been removed by me to see what was there but I put it back in
From my understanding the removed the old set up to install this new one with joystick controller
   / john deere 1050 joystick installation help!!!! #49
What is confusing then is the amount on rust of the valve block.
Did the new joystick assembly get put on the old valve body?
Some time ago I asked you for the complete CROSS identification for your DV valve.
What paper work do you have from the time the FEL valve was ordered
Dave M7040
It’s a new valve block. The parts house is suppose to get me that info on the valve today like the actual part number
Excavator Bucket (A49461)
Excavator Bucket...
2018 Bobcat T590 Compact Track Loader Skid Steer (A50322)
2018 Bobcat T590...
42in Hydraulic Forks Forklift Attachment (A49346)
42in Hydraulic...
WHITE CI-7 DRAW WORKS POWERED BY TWIN DETROIT 12.7S (A50854)
WHITE CI-7 DRAW...
Auger (A50860)
Auger (A50860)
2022 Case TR340B Skidloader (RIDE AND DRIVE) (A50774)
2022 Case TR340B...
