JD 5403 engine block coolant drain plug
/ JD 5403 engine block coolant drain plug #1
redkar
JD5103, JD5403
I have searched the net and cannot find answer. Where is the engine block drain plug for coolant antifreeze? I see a bolt head on the left side of the engine near the fuel pump, but not sure that's it. TBN is a great site. Thanks.
/ JD 5403 engine block coolant drain plug #2
Welcome to TBN
Some photos or two of the "bolt" head that might be a block drain would possibly help someone clarify for you.
Try this link to see if it helps.
Thanks for the reply. The procedure in the link is in the owners manual. Removing the thermostat requires removing several other items. Not a quick, easy task. I was hoping to simply drain the block and the radiator, flush and refill coolant.
2011 Ford F750 Dump Truck (A62613)
2011 Ford F750...
Pelican Paddle Boat (A65579)
Pelican Paddle...
1990 FRUEHAUF 53' DRY VAN TRAILER (A64280)
1990 FRUEHAUF 53'...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
Packer 750 Horizontal Grinder (A65579)
Packer 750...
2014 Cadillac ATS Sedan (A59231)
2014 Cadillac ATS...
