JD 5105 hydraulic problems
/ JD 5105 hydraulic problems #1
rharry5105
JD 5105
Newbie in the group,
I bought my 5105 in 2000 and only experienced hydraulic prblems all else is fine.
I have 380 hrs in the engine, yes I still want/need the tractor...
I have replaced 3 "rock shafts" under the seat to fix the 3-point from locking up.
Now the hydraulic system is getting slowly worse to the point yesterday that the bucket lifting was delayed a secound or two and the pwr steering was on and off. The 3-pt is very slow to move also.
I have changed the big spin on twice now and added fluid. The rear sight glasses have a small amount, 1/8", of gray in the bottom of the circles.
What do I have to look forward to ?
thanks,
Rich
/ JD 5105 hydraulic problems #3
I would suggest, if you do not get an answer in a day or so. You might consider posting your question in the General Forum/Hydraulics or the John Deere/Owning/Operating.
Also if you have not purchase a tech. manual you might consider that. Included is a URL to get a manual from John Deere or get the manual number and look on e-bay.
Sorry can not give you more help.
Operator's Manuals for John Deere Equipment
/ JD 5105 hydraulic problems #5
Rich, I have the tech manual in a PDF if you need it
Just shoot me your email
Joe
/ JD 5105 hydraulic problems #6
Almost sounds like air entrained in the system.
Could have a suction leak.
What color is the fluid?
A pressure test and flow test would be a good idea. If you don't see the system pressure, look at the pump closely.
/ JD 5105 hydraulic problems #7
gray as in bubbles or water? drain the fluid out of it then take the screen out and clean it ,then change the filter. check the fluid for water. go to the jd place and buy the correct grade of fluid for your tractor.it does make a differance. the screen comes out the back just above the drawbar.
/ JD 5105 hydraulic problems #10
on the way
2020 Ford F-150 4x4 Ext. Cab Pickup Truck (A64194)
2020 Ford F-150...
2142 (A65055)
2142 (A65055)
2012 Infiniti QX56 SUV (A64557)
2012 Infiniti QX56...
LONG PTO 5" X 6" IRRIGATION PUMP (A64278)
LONG PTO 5" X 6"...
2017 Ford F-150 4x4 Pickup Truck (A64556)
2017 Ford F-150...
2015 IC Corporation PB105 School Bus (A61573)
2015 IC...
