JD 4400 Power Steering/3PH Problems
/ JD 4400 Power Steering/3PH Problems #21
Hi there, I just wandered if you ever found out why the power steering was heavy on your company tractor. I have the same issues with my 4400 fitted with the 300cx loader. Very annoying how heavy it is! Thanks Julian
I removed a tie rod end on steering ram and still have heavy steering. I've read about a suction filter, could it be sorry and causing my problems. Where is it located on the 4400? Thanks
/ JD 4400 Power Steering/3PH Problems #22
I believe there is a pressure relief for the power steering circuit. If you have the manual it tells you how to check the pressure. I would start there.
2017 TROXELL 150 BBL ALUMINUM VACUUM TRAILER (A65643)
2017 TROXELL 150...
New/Unused ATS 40 Gallon Two Stage Air Compressor (A65583)
New/Unused ATS 40...
Heavy Duty Steel Baskets (A65579)
Heavy Duty Steel...
Landhonor Quick Attach Hydraulic Pallet Forks (A66408)
Landhonor Quick...
2011 Peterbilt 365 Altec AC38-127S 38 Ton Straight Boom Crane Truck (A61568)
2011 Peterbilt 365...
JOHN DEERE 1705 - 6R30" VACUUM PLANTER (A64277)
JOHN DEERE 1705 -...
