JD 4400 Power Steering/3PH Problems
   / JD 4400 Power Steering/3PH Problems #21
Hi there, I just wandered if you ever found out why the power steering was heavy on your company tractor. I have the same issues with my 4400 fitted with the 300cx loader. Very annoying how heavy it is! Thanks Julian
I removed a tie rod end on steering ram and still have heavy steering. I've read about a suction filter, could it be sorry and causing my problems. Where is it located on the 4400? Thanks
   / JD 4400 Power Steering/3PH Problems #22
I believe there is a pressure relief for the power steering circuit. If you have the manual it tells you how to check the pressure. I would start there.
JCB 2145 (A47477)
JCB 2145 (A47477)
2008 TEXAS BRAGG 20 UTILITY TRAILER (A55745)
2008 TEXAS BRAGG...
2006 Hackney T/A Hazmat Truck (A56858)
2006 Hackney T/A...
2013 Cummins DSGAB 125kW Standby Diesel Generator (A56857)
2013 Cummins DSGAB...
2015 DRAGON 130 BBL VACUUM TRAILER (A58214)
2015 DRAGON 130...
2025 Swict 84in Bucket Skid Steer Attachment (A56857)
2025 Swict 84in...
