JD 4310 wont go into reverse
   / JD 4310 wont go into reverse #1
Cowboyup4Christ
Ventura County, CA
JD 4310
I have a JD 4310 ePowerReverse. Just went to go use the tractor and was driving around with no problem. I went to put the tractor in reverse and it moved backwards about 2ft and would not move any more. The indicator lamp had 1 long flash then 2 short flashes pause 2 short flashes then a long flash and would repeat. Anyone know what code? I would post a video of it but won't let me. The rodents have been relentless and don’t know if any wires may be chewed and causing this. Any help would be appreciated!
   / JD 4310 wont go into reverse #2
Put video on YouTube and then link to that in your post. Should work then..
Was able to get a manual and figure it out. Did the trouble shooting like the picture shows and found the wire that was chewed through. IMG_1689.JPG
   / JD 4310 wont go into reverse #4
That was FAST trouble shooting. Thanks for posting the solution that worked.
   / JD 4310 wont go into reverse #6
Glad ya got it fixed so easy!!!!
   / JD 4310 wont go into reverse #7
Glad it's fixed, without a major repair.
2023 RTVXG-850 SideKick (A56438)
2023 RTVXG-850...
Wagon Wheel Rocking Chairs (A55758)
Wagon Wheel...
2019 ALLMAND MAXI-POWER 25 GENERATOR (A58214)
2019 ALLMAND...
Friesen 240 Seed Tender (A59814)
Friesen 240 Seed...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
2015 Peterbilt Dump Truck (A55973)
2015 Peterbilt...
