JD 4310 wont go into reverse
/ JD 4310 wont go into reverse #1
Cowboyup4Christ
Ventura County, CA
JD 4310
I have a JD 4310 ePowerReverse. Just went to go use the tractor and was driving around with no problem. I went to put the tractor in reverse and it moved backwards about 2ft and would not move any more. The indicator lamp had 1 long flash then 2 short flashes pause 2 short flashes then a long flash and would repeat. Anyone know what code? I would post a video of it but won't let me. The rodents have been relentless and don’t know if any wires may be chewed and causing this. Any help would be appreciated!
/ JD 4310 wont go into reverse #2
Put video on YouTube and then link to that in your post. Should work then..
Was able to get a manual and figure it out. Did the trouble shooting like the picture shows and found the wire that was chewed through. IMG_1689.JPG
/ JD 4310 wont go into reverse #4
That was FAST trouble shooting. Thanks for posting the solution that worked.
/ JD 4310 wont go into reverse #6
Glad ya got it fixed so easy!!!!
/ JD 4310 wont go into reverse #7
Glad it's fixed, without a major repair.
2026 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2026 SDLANCH...
BOWMAN WEED WICK & MOUNT (A63291)
BOWMAN WEED WICK &...
2018 CATERPILLAR 320 EXCAVATOR (A62129)
2018 CATERPILLAR...
2010 FORD RANGER SINGLE CAB PICKUP TRUCK (A59912)
2010 FORD RANGER...
1995 John Deere 5200 45HP 4x4 Utility Tractor (A61572)
1995 John Deere...
2016 TAKEUCHI TB240 EXCAVATOR (A64279)
2016 TAKEUCHI...
