JD 4310 wont go into reverse
   / JD 4310 wont go into reverse #1
Cowboyup4Christ
Ventura County, CA
JD 4310
I have a JD 4310 ePowerReverse. Just went to go use the tractor and was driving around with no problem. I went to put the tractor in reverse and it moved backwards about 2ft and would not move any more. The indicator lamp had 1 long flash then 2 short flashes pause 2 short flashes then a long flash and would repeat. Anyone know what code? I would post a video of it but won't let me. The rodents have been relentless and don’t know if any wires may be chewed and causing this. Any help would be appreciated!
   / JD 4310 wont go into reverse #2
Put video on YouTube and then link to that in your post. Should work then..
Was able to get a manual and figure it out. Did the trouble shooting like the picture shows and found the wire that was chewed through. IMG_1689.JPG
   / JD 4310 wont go into reverse #4
That was FAST trouble shooting. Thanks for posting the solution that worked.
   / JD 4310 wont go into reverse #6
Glad ya got it fixed so easy!!!!
   / JD 4310 wont go into reverse #7
Glad it's fixed, without a major repair.
Caterpillar D5G LGP (A53317)
Caterpillar D5G...
HIGH END MINI GOLF CART (A58214)
HIGH END MINI GOLF...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55853)
2006 iDrive...
2015 Goose Neck Cattle Trailer (A53317)
2015 Goose Neck...
1660 (A59213)
1660 (A59213)
J and L Cargo Express Shadowmaster Enclosed Trailer (A56436)
J and L Cargo...
