JD 4310 wont go into reverse
   / JD 4310 wont go into reverse #1
Cowboyup4Christ
Ventura County, CA
JD 4310
I have a JD 4310 ePowerReverse. Just went to go use the tractor and was driving around with no problem. I went to put the tractor in reverse and it moved backwards about 2ft and would not move any more. The indicator lamp had 1 long flash then 2 short flashes pause 2 short flashes then a long flash and would repeat. Anyone know what code? I would post a video of it but won't let me. The rodents have been relentless and don’t know if any wires may be chewed and causing this. Any help would be appreciated!
   / JD 4310 wont go into reverse #2
Put video on YouTube and then link to that in your post. Should work then..
Was able to get a manual and figure it out. Did the trouble shooting like the picture shows and found the wire that was chewed through. IMG_1689.JPG
   / JD 4310 wont go into reverse #4
That was FAST trouble shooting. Thanks for posting the solution that worked.
   / JD 4310 wont go into reverse #6
Glad ya got it fixed so easy!!!!
   / JD 4310 wont go into reverse #7
Glad it's fixed, without a major repair.
1978 Gray 48RM Vertical Boring Machine (A59213)
1978 Gray 48RM...
Westendorf TA-29 Loader (A59814)
Westendorf TA-29...
CAT 930M (A58214)
CAT 930M (A58214)
2018 Kubota RTV500 4x4 Diesel Utility Cart (A59228)
2018 Kubota RTV500...
2023 FORD F-150 XL CREW CAB TRUCK (A59823)
2023 FORD F-150 XL...
2016 VOLVO VNL780 SLEEPER (A59575)
2016 VOLVO VNL780...
