JD 4310 wont go into reverse
/ JD 4310 wont go into reverse #1
Cowboyup4Christ
Ventura County, CA
JD 4310
I have a JD 4310 ePowerReverse. Just went to go use the tractor and was driving around with no problem. I went to put the tractor in reverse and it moved backwards about 2ft and would not move any more. The indicator lamp had 1 long flash then 2 short flashes pause 2 short flashes then a long flash and would repeat. Anyone know what code? I would post a video of it but won't let me. The rodents have been relentless and don’t know if any wires may be chewed and causing this. Any help would be appreciated!
/ JD 4310 wont go into reverse #2
Put video on YouTube and then link to that in your post. Should work then..
Was able to get a manual and figure it out. Did the trouble shooting like the picture shows and found the wire that was chewed through. IMG_1689.JPG
/ JD 4310 wont go into reverse #4
That was FAST trouble shooting. Thanks for posting the solution that worked.
/ JD 4310 wont go into reverse #6
Glad ya got it fixed so easy!!!!
/ JD 4310 wont go into reverse #7
Glad it's fixed, without a major repair.
2004 VOLVO VHD TRI/A CEMENT MIXER TRUCK (A59911)
2004 VOLVO VHD...
2006 Cadillac GM Superior Coach 6-Door Limousine - Only 21,567 Miles (A63688)
2006 Cadillac GM...
Sterling AT (A63689)
2017 Ford F-550 4x4 Venturo ET25KX 2 Ton Crane Service Truck (A61573)
2017 Ford F-550...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A63688)
2023 Kubota...
