JD 3020 checking hyd level?
/ JD 3020 checking hyd level? #1
MNBobcat
Platinum Member
I blew a hydraulic line. When I replaced the line I drained all of the hyd fluid and replaced it along with a new filter. Now I have a stumble in the FEL. If I run it to full extension a few times the stumble goes away until first start on the next day.
When I check the hyd level via the dipstick, should the stick be sitting on top or screwed all the way down and then removed when you check the level?
/ JD 3020 checking hyd level? #2
From the manual, "With the tractor on level ground, remove the dipstick. Obtain the oil level on the dipstick with the cap resting on the threads."
You do have a manual right? :D
Tim
Tim,
Thanks. Nope, just got the tractor within the last 2 months and haven't picked up a manual for it yet.
New/Unused Wolverine 72in Tiller (A65583)
New/Unused...
Aluminum Mermaid (A65583)
Aluminum Mermaid...
2012 Palomino Ultra-Lite Camper / Travel Trailer (A66285)
2012 Palomino...
Club Car Emergency Cart (A64557)
Club Car Emergency...
2014 Toyota Tacoma Ranch Camper Shell (A64126)
2014 Toyota Tacoma...
2022 EZ-GO ELITE...
