JD 3005 Hood
/ JD 3005 Hood #1
Plane4
Chicago, IL
John Deere 3005
Ok call me stupid but how do you open the hood on a JD 3005 with FEL? I know about the front pin in the side grill and I can pull it out. I can also pull the front grill out slightly toward the loader but nothing else. I havn't found any other hood latches and it doesn't just raise up....
Thanks
/ JD 3005 Hood #2
Pulling out the side latch should open it. You my have pull hard on latch if not adjusted right. Sometimes my 790 hood would catch the turn latches for the side covers, and I would pull out slightly on the side. To remove grille you have to remove top bolts in grille guard and tilt foward. Hope this helps
/ JD 3005 Hood #3
You have to lift it from the front after pulling the latch at the right front
/ JD 3005 Hood #4
Pull the side latch and the hood should pop up a little, Lift from the front. The not designed well tabs that hold the side panels do affect hood closing and opening at times....
2019 FORD F350 4X4 PICKUP TRUCK (A59914)
2019 FORD F350 4X4...
20x20 Car Port (A65640)
20x20 Car Port...
2016 Peterbilt 389 Day Cab (A62613)
2016 Peterbilt 389...
2012 International DuraStar 4300 Digger (A62613)
2012 International...
New/Unused ATS Welding Machine (A65583)
New/Unused ATS...
Massey Ferguson 573 (A64126)
Massey Ferguson...
