JD 3005 Hood
/ JD 3005 Hood #1
Plane4
Chicago, IL
John Deere 3005
Ok call me stupid but how do you open the hood on a JD 3005 with FEL? I know about the front pin in the side grill and I can pull it out. I can also pull the front grill out slightly toward the loader but nothing else. I havn't found any other hood latches and it doesn't just raise up....
Thanks
/ JD 3005 Hood #2
Pulling out the side latch should open it. You my have pull hard on latch if not adjusted right. Sometimes my 790 hood would catch the turn latches for the side covers, and I would pull out slightly on the side. To remove grille you have to remove top bolts in grille guard and tilt foward. Hope this helps
/ JD 3005 Hood #3
You have to lift it from the front after pulling the latch at the right front
/ JD 3005 Hood #4
Pull the side latch and the hood should pop up a little, Lift from the front. The not designed well tabs that hold the side panels do affect hood closing and opening at times....
New/Unused Landhonor 21ft x 13ft Metal Carport (A65583)
New/Unused...
New/Unused Landhonor 8ft x 10ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
Ingersoll Rand Roller (A64553)
Ingersoll Rand...
Bear Statue (A64127)
2007 Freightliner FLD120 (A62679)
2007 Freightliner...
2014 Bobcat T870 (A64126)
2014 Bobcat T870...
