JD 2030 Tractor SERIAL #?
/ JD 2030 Tractor SERIAL #?
Tach cable attaches to RH side of flywheel housing under battery box & drives from end of camshaft. I agree I have thought it was a 2020 since near the beginning of this thread.
thanks, where about does the end of the wire connect on the camshaft. do u have a pic?
/ JD 2030 Tractor SERIAL #? #62
Sorry but I couldn't locate a photo.
/ JD 2030 Tractor SERIAL #? #64
In the drawing from jd parts, key 20 is showing a plug (if no tach) this is where the tach cable connects. Upper right side of clutch housing
/ JD 2030 Tractor SERIAL #? #65
Well DUH!!!! Thanks Z5 for posting photo. I wasn't considering the clutch housing was bolted BEHIND flywheel housing.
help out a dummy... where exactly is the upper right side of clutch housing? tx
/ JD 2030 Tractor SERIAL #? #67
As I stated earlier the tach cable connection is under RH side of battery box
2011 MULTIQUIP LIGHT PLANT/ FUEL TANK TRAILER (A67714)
2011 MULTIQUIP...
CAT D250E Transmission (A68134)
CAT D250E...
CAT 963 4-in-1 Bucket (A68134)
CAT 963 4-in-1...
2007 Freightliner M2 106 Pothole Patcher Truck (A66736)
2007 Freightliner...
2019 Nissan Kicks Hatchback (A66738)
2019 Nissan Kicks...
Baby Goat Decorative Statue (A66738)
Baby Goat...
