JD 2030 Tractor SERIAL #?
/ JD 2030 Tractor SERIAL #?
Tach cable attaches to RH side of flywheel housing under battery box & drives from end of camshaft. I agree I have thought it was a 2020 since near the beginning of this thread.
thanks, where about does the end of the wire connect on the camshaft. do u have a pic?
/ JD 2030 Tractor SERIAL #? #62
Sorry but I couldn't locate a photo.
/ JD 2030 Tractor SERIAL #? #64
In the drawing from jd parts, key 20 is showing a plug (if no tach) this is where the tach cable connects. Upper right side of clutch housing
/ JD 2030 Tractor SERIAL #? #65
Well DUH!!!! Thanks Z5 for posting photo. I wasn't considering the clutch housing was bolted BEHIND flywheel housing.
help out a dummy... where exactly is the upper right side of clutch housing? tx
/ JD 2030 Tractor SERIAL #? #67
As I stated earlier the tach cable connection is under RH side of battery box
John Deere 700 H Dozer (A62679)
John Deere 700 H...
Unused 2023 Kubota AP-SSG2024 24in. Hydraulic Stump Grinder Skid Steer Attachment (A66734)
Unused 2023 Kubota...
2016 Freightliner M2 106 Brush Hawg Grapple Truck (A66736)
2016 Freightliner...
2007 WESTERN STAR  4900 TRI AXLE (A67714)
2007 WESTERN STAR...
2021 Jeep Gladiator 4x4 Crew Cab Pickup Truck (A66736)
2021 Jeep...
HYDRAULIC MANIFOLD SKID (A67714)
HYDRAULIC MANIFOLD...
