JD 2030 Tractor SERIAL #?
/ JD 2030 Tractor SERIAL #?
Tach cable attaches to RH side of flywheel housing under battery box & drives from end of camshaft. I agree I have thought it was a 2020 since near the beginning of this thread.
thanks, where about does the end of the wire connect on the camshaft. do u have a pic?
/ JD 2030 Tractor SERIAL #? #62
Sorry but I couldn't locate a photo.
/ JD 2030 Tractor SERIAL #? #64
In the drawing from jd parts, key 20 is showing a plug (if no tach) this is where the tach cable connects. Upper right side of clutch housing
/ JD 2030 Tractor SERIAL #? #65
Well DUH!!!! Thanks Z5 for posting photo. I wasn't considering the clutch housing was bolted BEHIND flywheel housing.
help out a dummy... where exactly is the upper right side of clutch housing? tx
/ JD 2030 Tractor SERIAL #? #67
As I stated earlier the tach cable connection is under RH side of battery box
2018 GENERAC MOBILE PRODUCTS MLT6S (A67714)
2018 GENERAC...
2013 WACKER NEUSON LTN8 LIGHT PLANT (A68842)
2013 WACKER NEUSON...
2008 MACK CHU613 DAYCAB (INOPERABLE) (A67714)
2008 MACK CHU613...
TOTE OF ROAD SIGNS AND TWIST LOCKS (A68842)
TOTE OF ROAD SIGNS...
NEW HOLLAND T4020 TRACTOR (A65057)
NEW HOLLAND T4020...
SARLO (A64557)
SARLO (A64557)
