JD 2030 Tractor SERIAL #?
/ JD 2030 Tractor SERIAL #?
Tach cable attaches to RH side of flywheel housing under battery box & drives from end of camshaft. I agree I have thought it was a 2020 since near the beginning of this thread.
thanks, where about does the end of the wire connect on the camshaft. do u have a pic?
/ JD 2030 Tractor SERIAL #? #62
Sorry but I couldn't locate a photo.
/ JD 2030 Tractor SERIAL #? #64
In the drawing from jd parts, key 20 is showing a plug (if no tach) this is where the tach cable connects. Upper right side of clutch housing
/ JD 2030 Tractor SERIAL #? #65
Well DUH!!!! Thanks Z5 for posting photo. I wasn't considering the clutch housing was bolted BEHIND flywheel housing.
help out a dummy... where exactly is the upper right side of clutch housing? tx
/ JD 2030 Tractor SERIAL #? #67
As I stated earlier the tach cable connection is under RH side of battery box
2018 HARPER ATM 72LC MOWER (A66091)
2018 HARPER ATM...
MF GC2300 fel replaced
GENIE GTH-842 TELESCOPIC FORKLIFT (A65056)
GENIE GTH-842...
2018 BOBCAT E26 (A68134)
2018 BOBCAT E26...
Generator (A64553)
Generator (A64553)
2021 John Deere 4044M (A64126)
2021 John Deere...
