JD 2030 Tractor SERIAL #?
/ JD 2030 Tractor SERIAL #?
Tach cable attaches to RH side of flywheel housing under battery box & drives from end of camshaft. I agree I have thought it was a 2020 since near the beginning of this thread.
thanks, where about does the end of the wire connect on the camshaft. do u have a pic?
/ JD 2030 Tractor SERIAL #? #62
Sorry but I couldn't locate a photo.
/ JD 2030 Tractor SERIAL #? #64
In the drawing from jd parts, key 20 is showing a plug (if no tach) this is where the tach cable connects. Upper right side of clutch housing
/ JD 2030 Tractor SERIAL #? #65
Well DUH!!!! Thanks Z5 for posting photo. I wasn't considering the clutch housing was bolted BEHIND flywheel housing.
help out a dummy... where exactly is the upper right side of clutch housing? tx
/ JD 2030 Tractor SERIAL #? #67
As I stated earlier the tach cable connection is under RH side of battery box
2006 HONDA ACCORD (A65057)
2006 HONDA ACCORD...
2014 MAGNUM TRAILER (A68842)
2014 MAGNUM...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A66734)
2025 Kivel 48in...
2002 Lexus RX 300 SUV (A66738)
2002 Lexus RX 300...
2015 Kubota RTV-X900 4x4 Diesel Utility Cart (A66734)
2015 Kubota...
2012 COMPTANK  ACID TRANSPORT TRAILER (A67714)
2012 COMPTANK...
