It’s here!
/ It’s here! #21
The hydro pedals are quite stiff… I think I’ve read this before, but it only has 2.5 hours on the meter. The range shift is so buttery smooth. I’ve had it in all 4-ranges, and it is effortless. Ive not used the cruise control as of yet, but I imagine that will be handy when I want to creep across the field with the tiller.
I will be measuring for a hydraulic top link today, and greasing up the 3-pt arm adjustments as feel awfully dry, though free.
These early bonding moments are very important when it comes to the success of a long-term relationship.
/ It’s here!
So one rear remote lever is quite stiff… it’s the detent lever. So stiff I saw the bracket underneath flex a bit. I then discovered that the bracket for the linkages was not properly installed. It is a large “L” shaped bracket with two bolt holes for the side of the transmission and two on top of the transmission. Thus the “L” shaped bracket. Well, the top bolts were not installed.
I can get some bolts and do so, though it appears I’ll have to remove the seat pan area to get good access to the bolt holes. Not insurmountable, but disappointed a little. A long reach pneumatic wrench will likely do the trick.
Also, adjusted tire pressures. The fronts were 50psi… dropped to 30 per a chart on the interweb. The rears were at 23psi, so I left them alone.
/ It’s here!
Cleaning the paint up and getting it protected.
/ It’s here! #24
Exciting times, enjoy every minute of it.
/ It’s here!
Got the bolt specs for the remote valve bracket from the dealer today, so I may find time to fiddle with that. Not insurmountabl, but I may need my wife’s hands to get in there
/ It’s here!
Service department claims they installed both bolts, but they must have rattled out… when the tractor has only run for perhaps 15 minutes since install. No, they didn’t, please just be honest. They sent me the spec for the bolts, however I bought the incorrect length… so they bottomed out well before tightening the bracket. So, back to the drawing board. I should have the parts needed by next week to finish up the bracket install. Getting to the bolt under the seat may require some ingenuity
/ It’s here! #27
My last two new Kubotas had minor assembly issues also. Both with hydraulics connections being loose.
I didn't lose too much sleep over it, and it sounds like you're not either.
/ It’s here!
Nah, it’s a couple bolts and scraped up hands. Things happen. Two people called today to apologize… I just really needed to know the bolt size 😂
/ It’s here! #29
Given the mess that hiring has been since 2021, we will probably see more. The problem is not entirely new, though.
I remember when I was a kid, my cousin explained that his motorcycle dealer would intentionally leave minor problems for him to find. It was supposed to teach him how to fix things himself. I don't know if it was that or the dealer covering errors in his shop.
/ It’s here!
A few more photos of cleaning and making sure everything is lubed.
I was surprised that the removable radiator screen pulls UP, which means you have to detach the air intake tube to clear it. Every video I thought I had seen, it pulled clear from the side. Nope. Oh well.
/ It’s here! #31
Nice...darn that nice (y) emjoy.
/ It’s here!
HYD top link ordered. Already have the 3pt quick hitch in the shop… in a week the back end should be ready to go!
/ It’s here!
I got the two bolts installed under the seat pan for the bracket for the remote lever mechanism.
The Italian made top link arrives tomorrow. One day ship, free ship! And, it is the same color as the Branson charcoal gray.
Tonight I will be working on the 3-pt quick hitch upper hook, as the Harbor Freight hitch needed an aftermarket hook. I still need to clean and maybe ceramic coat the paint… but we will get there.
I need bushings yet for the implements
/ It’s here! #35
That barn is no shabby shack either. (y)
/ It’s here! #37
Looks good enjoy.
/ It’s here!
Top link has arrived from AgriSupply. One day ship, for free, Italian made… great packaging.
/ It’s here! #39
Nice. I wonder if the same one will fit the T574. Somehow, I think there are enough differences that I cannot just follow your lead.
2000 Sterling L9511 Triaxle Dump Truck, VIN # 2FZNNWYB8YAB42893 (A65563)
2000 Sterling...
2014 JOHN DEERE 648H SKIDDER (A62129)
2014 JOHN DEERE...
2013 DRAGON  130BBL VACUUM TRAILER (A65643)
2013 DRAGON...
Cattle Feeder (A65640)
1024 (A63111)
1024 (A63111)
2025 Auger Bits Skid Steer Attachment (A61567)
2025 Auger Bits...
