Iseki TU 160F
   / Iseki TU 160F #1
royzone
Iseki TU 160F
Hi
I just bought my first tractor, as a project to renovate. I have no documents for it and the ID plate is so rusty I cant read it. From what I,ve seen on the internet it is a TU 160F probably made 1984/86. It has a 3 cylinder 16hp Mitsubishi engine (I think)
It starts but the clutch is seized and I think the electrics have been modified.
I desperately want an owners manual that I can refer to , I have searched the internet but cant find anything.
Can anyone out there help.
Roy
   / Iseki TU 160F #5
I have not found one specifically for the tu160. I do have a TU series owner's manual.
   / Iseki TU 160F
Hi
I see you are also in Uk. I think problem you had with starter is same with me.Turning key just makes a click, sometimes a rapid set of clicks but starter motor does,nt fire.I have noticed that battery negative lead gets very hot and smokes.Any ideas.
Roy
   / Iseki TU 160F #8
hi where in the uk are you? id take the starter motor and try it on the bench, bypassing the solenoid then go from therer
   / Iseki TU 160F
Hi I,m in Hebden Bridge West Yorks. I,ve decided to get the engine out so I can have a proper look at everything, so I will take starter off and have a look.
   / Iseki TU 160F #10
good idea, is it the 3af1 engine? thats what my tu1900 has which is 3 cylinder
2012 Nissan Rogue (A50324)
2012 Nissan Rogue...
Bobcat 3400 4x4 Utility Cart (A51691)
Bobcat 3400 4x4...
2019 JOHN DEERE 310SL HL BACKHOE (A51406)
2019 JOHN DEERE...
JLG 1255 Telehandler (A52748)
JLG 1255...
2012 Vicon Andex 423T (A50120)
2012 Vicon Andex...
(4) Semi Tires (A50121)
(4) Semi Tires...
