Is it really overheating?
/ Is it really overheating? #11
Have you priced a waterpump? you are looking at $200+.
/ Is it really overheating? #12
/ Is it really overheating? #13
I think you're entirely on the right track, you've already invested the money in the tractor and mower, a few more $$ to make sure it's up to snuff is a worthwhile investement. It could be that it's not overheating, you've just got a faulty sender. Fine. But adding a water pump means you can set your coolant to a 50/50 ratio and not have to worry about freezing (don't know if this is a problem where you are) and know that you're getting optimum performance from your machine. Seems like a reasonable course of action to me...........
/ Is it really overheating? #14
/ Is it really overheating? #15
Put a temp gauge on first and see what the actual temp is. You know you really want to put one on anyway........ /forums/images/graemlins/grin.gif
Plenty of them out there at the auto parts stores. I used a Sunpro on mine, came with metric fittings too.
/ Is it really overheating? #16
/ Is it really overheating? #17
When I had my 1700, here in Mississippi, with a 4 foot bush hog, mine didn't get hot, and I would mow for hours with it, in mid summer. Well, it did at first, till I replaced the radiator cap, and bought a sending unit from Hoye, that only cost I think it was a cheap price, and never thought of putting a water pump on. They made these tractors to be used, and they knew what they were doing and what was needed on them, it works fine without a water pump.
/ Is it really overheating? #18
Well, I'm at least partly swayed by pruntyc's comments about his tractor working in Miss. It certainly doesn't get any worse around here. That may be worth an initial try (maybe with a temp gauge). It's not the $200 (actually, I think it's $300) for the pump that bothers me so much, but the thought of removing and replacing the radiator multiple times if I decide it needs to be cleaned. If the radiator comes off again, a water pump goes on :).
1408 (A57192)
1408 (A57192)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2017 ADDCO ROAD SIGN DH1000-ALS (A60736)
2017 ADDCO ROAD...
UNUSED 89" LAND PLANE (A52706)
UNUSED 89" LAND...
Commercial Lawn Mower 652R (A56859)
Commercial Lawn...
2019 Deere 35G (A53317)
2019 Deere 35G...
