Is it really overheating?
/ Is it really overheating? #51
Nobody has mentioned this, but does your machine have a thermostat?? If so, it could well need replacing. I've had that problem with cars and trucks a few times, running hot, yet the radiator was cool to the touch.
Worth checking to see before you waste any more time.
/ Is it really overheating? #52
/ Is it really overheating? #53
Welcome John47,
No thermostat on a YM1700.
Bruce
/ Is it really overheating? #54
Welcome John47,
Bruce
/ Is it really overheating? #55
How is the filter screen in front of your radiator? Is it clogged with debris? Is it there at all? I would gently blow the radiator fins out with an air gun. Do it from the fan side out. The little fins clog with seed heads etc... You can remove them with an air gun. don't get to close or use to high of pressure cuz u don't want to bend the little fins... If you do not have a radiator pre screen.....get one....Also run the 30/70 mixture and see how that goes.......
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55853)
2006 iDrive...
17307 (A55853)
17307 (A55853)
1996 CATERPILLAR D6E CRAWLER DOZER (A62129)
1996 CATERPILLAR...
Hobart Champion 16 AC/DC Engine-driven Welder and generator (A61307)
Hobart Champion 16...
900 GAL SEWAGE VACUUM BED (A60736)
900 GAL SEWAGE...
iDrive TDS-2010H...
