Is it really overheating?
/ Is it really overheating? #41
I didn't use air, I used a water hose, with one of those ends that makes it pretty high pressure. I did this several times to mine, from the fan side out. I couldn't believe the crud that came out of it. I guess that is why mine didn't run hot, as I did it soon after I bought it.
/ Is it really overheating? #42
/ Is it really overheating? #43
If you fill the radiator and it does it again, that would be the first step to trouble shooting it.
/ Is it really overheating? #44
/ Is it really overheating? #45
You are correct. I went home and took another look at it. I think I just assumed that because it was a red line that it was like the red line on car tachometer. It is good to know that I have not been running it too hard
/ Is it really overheating? #46
I couldn't get a 16mm bushing for the Sunpro gauge I got, so I took it back and ordered one of the more expensive ones from Hoye. I installed it this morning, filled the system with pure water, and started to do some testing.
Just running the tractor once around in a little circle in front of the house brought it up to about 190. About four times around a small field with the bush hog brought it up to about 230. At that point I quit. I notice that the top hose of the radiator is very hot to the touch and that the bottom hose is almost cold. Top of radiator is very hot; bottom is cold.
Aaron at Hoye says they mow just fine with a similar size cutter in 90+ weather and without a water pump, and that the temp hangs around 190.
I've done all the cleaning tricks, and flushing tricks I can and it's still running hot. So the next step (about the only think left short of a water pump) is to get the radiator to a shop and see what they can do or say about it.
/ Is it really overheating? #49
Yep, that radiator is still plugged up and a waterpump won't fix that.
/ Is it really overheating? #50
2021 Unverferth 432 Rigid 4 Row 36-inch 3PT Ripper Bedder (A61307)
2021 Unverferth...
Adams 350T 10T Tender (A61307)
Adams 350T 10T...
2003 Ford E-450 Super Duty Passenger Bus (A59230)
2003 Ford E-450...
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A52707)
2007 CATERPILLAR...
2006 BIG TEX 20 T/A GOOSENECK TRAILER (A60736)
2006 BIG TEX 20...
Hays LT-1 Tender (A61307)
Hays LT-1 Tender...
