Is it really overheating?
/ Is it really overheating?
I just ran down to Advance Auto and got a Sunpro gauge. The package says "metric fittings available", but it has three fittings with it, and it looks like one *might* fit -- can't tell just yet since I just moved the tractor and the block's hot right now. Nice looking gauge for only about $26.
If the fitting works, this should tell the tale -- not to mention being a slick "custom" addition to the dashboard :).
My wife thinks I should just stop fooling around and get the water pump. We'll see.
/ Is it really overheating? #25
I have a YM 1700 and thought it was running hot . I did a lot to it, had the radiator cleaned . Put a new head gasket on it , Put a new radiator cap on .Light was still coming on got a sending unit from Hoye and that fix it. .It was 92 the other day and I ran the 5 rotary cutter for 6 hour and the light did not come on.
/ Is it really overheating? #26
/ Is it really overheating? #27
I've gone through this same exact scenario. Get a new sending unit from Hoye and a set of guages. My 1700, on occassion, would kick the warning light on. I would stop, let her cool down, and then proceed. I did multiple flushes on the radiator and block running pure water in the summer to help out the thermo-syphion system. After I installed a set of guages I realized that these things,with a 14 psi radiator cap, run warm. I did put a water pump on for piece of mind but she still runs in the 200 to 220 range. No problem. Light goes on at 235. I think the boiling point is around 248 with a 14 psi radiator cap. So, if I were in your shoes, do the following.
1. New sending unit
2. Get a set of guages
3. Install a water pump if you want to
I like my pump. I never need to worry about her overheating anymore. Aaron at Hoye is great BTW. Cost is a tad over $300. Not a difficult install. Good luck!!!
/ Is it really overheating? #28
1. New sending unit
/ Is it really overheating? #29
If your radiator level is low and the overflow tank is full, does this mean your radiator cap is suspect?
Jerry
/ Is it really overheating? #30
Jerry
/ Is it really overheating? #31
I have been thru the same drill as you with my 1700 only to discover in the end that the temp sensor was bad. I have installed the gauge, had the radiator cleaned and rodded at a radiator shop too. I like having the peace of mind of the temp gauge too. I don't think the water pump is necessary. I can bushog all day long and the temp never gets above 190 unless the radiator screen gets clogged up. Which can happend quickly in tall grass. I run it hard 2400 rpms. The tractor seems to like it that way too.
/ Is it really overheating? #32
/ Is it really overheating? #33
If you are running the bush hog at 2400, you are putting a lot more pressure on the hog, than you are suppose to. It should be running more like 2200, so its at the right PTO speed for the hog. There is a red mark on the rpm gauge that tells you when you are running it at the right speed.
/ Is it really overheating? #34
/ Is it really overheating? #35
I run it a little shy of the red line. I thought the red line was 2400
/ Is it really overheating? #36
/ Is it really overheating? #37
</font><font color="blue" class="small">( I run it a little shy of the red line. I thought the red line was 2400 )</font>
If its a refurb it may have a meter showing the red 'pto' tic at 2400, but for a 1700 I think the tic should be at 2200 like prunty said. I've seen refurbs wih the wrong meter like this.
/ Is it really overheating? #38
/ Is it really overheating? #39
Have you checked your radiator fins for small debris?
My YM240 would run hot (230+ degrees) after 30 minutes of light cutting. Someone on the message board suggested I lightly blow compressed air through my radiator fins. When I did, dirt and grass came out of the radiator fins. Now my tractor never runs hot. I bushogged a tall 3 acre field the other day with a 5 ft cutter in 96 degree heat and never got above 210 degrees. Come to find out, the radiator screen to my tractor was missing. I made one out of an old window screen.
Just a thought.
/ Is it really overheating? #40
Just a thought.
2yd. Skid Steer Trash Hopper (A65640)
2yd. Skid Steer...
2022 Kaufman Trailers Trailer, VIN # 5VGFW5035NL009932 (A65563)
2022 Kaufman...
2009 Mariah SC23 23ft. Cabin Cruiser with T/A Boat Trailer (A61569)
2009 Mariah SC23...
2019 Ford Explorer AWD SUV (A64557)
2019 Ford Explorer...
Kubota Zero Turn Lawnmower (A65579)
Kubota Zero Turn...
2007 PETERBILT 386 (A65643)
2007 PETERBILT 386...
