X585 Engine Replacement
/ X585 Engine Replacement #1
gtunney
Bronze Member
East Hampden County, MA, USA
JD X585
Well, I've gone and committed to replacing the engine on my X585. I'm approaching 1120 hours on the FD711D engine. Compression is minimum spec on one piston and below spec on the other (90 and 70 as I recall). It is also burning at least a quart of oil between oil changes - enough that you smell it and I get comments from my treasurer on it. A couple months back, it started leaking coolant from underneath the water pump housing. I don't have the time or equipment to give the engine the attention it needs so I've been having my local dealer look at it and propose options.
A teardown to address the piston rings would not be inexpensive and addressing the coolant leak priced in at just over $1200. I started hunting around the forums here and elsewhere on engine fixes a while back, I found mention of RepowerPros. They offer a complete FD791D sans exhaust and radiator for $2950 + shipping and taxes where appropriate. I showed it to the JD mechanic who's been taking care of my machine (the X485/495 and X585/595 are his favorite tractors) and he said if Repower are true to their words, it would be a quicker and easier job than replacing the rings plus I get a zero time engine through and through. My JD mechanic's estimate for time to do the engine swap - just three hours. So, given where things were overall with the engine, I opted for the replacement. I found @4get gto 's post here about his JD 425 (https://www.tractorbynet.com/forums...builder-for-my-425-engine.435448/post-6134846). That post helped seal the deal for me. Not a cheap way to fix a water pump leak, but it fixes the rings issue two and gives me a new, zero-hour engine for a reasonable price.
I just ordered the engine yesterday afternoon and Repower called today to say the engine is shipping tomorrow. It's shipping from PA to CT so my dealer should have it by Friday. And I should get my machine back early next week. In my case, if there are any additional costs, it will be the possible need for new radiator hoses and exhaust/muffler. Will cross those bridges when the installation occurs. I'll post updates to include the mechanic's thoughts on the replacement process and how I feel about the performance. More to come.
/ X585 Engine Replacement #2
Sorry to hear it, but sounds like your best option to save time as well. Hope for the best.
Thanks, but I look at as an improvement opportunity. I hope the improvement is noticeable. My other more expensive option was to move up to a 1025R, but I already have pushed the space on my shed. I am already talking to one of the local shed providers to get a larger shed that could comfortably house a subcompact in the future if I choose to make that jump.
/ X585 Engine Replacement #4
Sad to hear the engine is worn out so soon!
My 1977 John Deere 300 has the original Kohler K431 engine in good condition and has not needed rebuilding, however I had to replace the shattered aluminum connecting rod over 25 years ago.
Still the original piston, rings etc. and never had to add engine oil so far.
Secret to survival: I always change the engine oil every 50 hours.
I got is used from the second owner with 560 hours on it. I think it may have gotten a bit abused at some point. It didn't help that I misunderstood the oil change intervals initially and was late with the first three changes and although I did ensure the level was maintained, overdue is overdue.
For those interested in what the installation instructions are that they send with the engine, attached is what they sent me for mine. I'm not sure if this a standard set of instructions or they adjust them based on what they are aware that buyer or installer knows.
  • X485 install instructions.pdf
/ X585 Engine Replacement #7
Repower Pros people seem pretty top notch.
That engine you're getting should be a direct replacement.
On a side story I but a brand new 28hp Kohler on a relatives wood chipper and he only got 70 hrs out it. Sinful to say the least. He said he always "always" cleans and changes the filters.
Come to find out he was reinstalling the filter wrong letting all that dust suck in.
I was told by my dealer that it should get installed today. I sure hope so. Grass is getting long and the leaves are getting deep!
Update. The engine arrived on Friday, Oct 24. The assigned mechanic had some work to complete on other jobs so wasn't expected to start on it until late Monday the 27th or early Tuesday, the 28th. Something came up that he had to take Monday off, so everything was delayed a day. Work started on Wednesday, the 29th. Late Thursday the install was completed, but not before addressing some confusion regarding fitment issues which were resolved once the service manager came into assist.
Friday, Halloween, during engine checkout, the ghosts got involved. First, the service rep thought it sounded like it was overspeeding at WOT despite it showing spec numbers on the tachometer. They decided to back the top limit down to 3200 rpm and I told them that isn't right because it's supposed to match the old engine spec rpm numbers. They call Repower who confirmed that, yes, the numbers should be the spec JD numbers for an X585 engine. So, we got that sorted out and they said it was running great.
Next, they told me they planned to deliver my tractor today, Monday, morning, but while I was on the phone with the service rep, a new gremlin cropped up - engine warning light due a fuel injection issue. This was late Friday afternoon.
I called this morning and when the came in, they found oil under the engine. Apparently, the drain tap is leaking and the threads on the drain valve appear to be stripped. They were about to call Repower again to try to resolve the leak issue and the continuing fuel injection light issue. So, I'm still without my tractor, sigh. More to come.
So, we are still trying to sort out the drain valve fitment issue. We ordered a new valve and it finally arrived today. That's the good news. The bad news is that fuel injection light appears to be tied to a blown input fuel line and the fuel line is on back order until December 19th!!!!! Not just my dealership, at every dealership across the country I've reached out to all over the country, but I'm continuing to look. If no one has it, I'll have them pull the line and take it to an auto parts store to have it made. As it is, this thing is listing for $250 to $280. One shop has a fall parts sale going and I could possibly get it from them, but I'm waiting to hear back if it is in stock. That's my last shot before going the hose rebuild route.
Happy Thanksgiving, everyone!!! My re-engined X585 finally came home last night. The desk service rep brought it himself once he determined that he could not get the delivery on yesterday's schedule. It was after dinner and dark by the time he was able to get to me so the only thing I did was check the RPM settings which seem to be about 100 rpm below spec and put it in the shed. I will take a closer look tomorrow. They did point out that they lost one of the screws in the right rear fender handle and have the screw on order (you'd think that would be common stock). Not sure why the tech felt the need the take that handle off as it is not part of the procedure for removing the rear fender deck. They also put the 2wd-4wd selector knob on backward which is an easy fix. Engine sounds slightly higher pitched, but also quieter overall. More to come.
Caterpillar 70in Loader Forks and Frame Attachment (A61572)
Caterpillar 70in...
Landhonor MPF-11-2000G Skid Steer Pallet Forks  (A62679)
Landhonor...
2022 EZ-GO ELITE...
2010 GREAT DANE SUP-1114-31053 T/A REFRIGERATED TRAILER (A59914)
2010 GREAT DANE...
John Deere 1530 Tractor (A66285)
John Deere 1530...
Minneapolis-Moline U Tractor (A66285)
Minneapolis-Moline...
