Insulating my shop
/ Insulating my shop #11
I have trusses. These foam inserts are called rafter vents, that is the only time I mentioned rafters.
You said that you were going to use batt insulation "between the rafters". Anyway, are you planning to put the batts between the top chords or bottom chords of the trusses? Ideally, the insulation should be between the bottom chords and then a vapor barrier should be installed under that before the ceiling. This allows plenty of airflow above the insulation. You'll also want to make sure that your ridge is vented properly. If it isn't, eave vents won't help.
  • Good Post
Reactions: JJT
2007 Ingersoll Rand G240 214kW 3-Phase Towable Diesel Generator (A59228)
2007 Ingersoll...
2012 UTILITY REEFER TRAILER (A58018)
2012 UTILITY...
FOUR WAY BLADE SKID STEER ATTACHMENT (A58214)
FOUR WAY BLADE...
GOODYEAR SET OF 12.4/11-24 TIRES WITH 5 BOLT HUB WHEELS (80% TREAD) (A55315)
GOODYEAR SET OF...
2003 Ford F-150 4x4 Crew Cab Pickup Truck (A59230)
2003 Ford F-150...
2017 Nissan Rogue SUV (A59231)
2017 Nissan Rogue...
