Stove Pipe
/ Stove Pipe #31
Additionally... Biomass (pellet and corn burning appliances) don't produce creosote if vented and operating properly.
All they produce is fine fly ash, no creosote what so ever and why they mist be maintained religiously and often as the fly ash will plug them up. When I'm using mine, they get cleaned internally at least weekly and I take apart the external venting and clean it inside a couple times during the heating season plus my external venting has a removable fly ash trap at the bottom of the vertical outside pipe run that gets dumped weekly and of course all of that is extremely messy.
Like I said previously, with the cost of manufactured pellets today, they are almost cost prohibitive to operate unless you can buy pellets in truckload quantities which I have in the past. truckload quantity is usually 22 skids of pellets delivered on a tractor trailer and the skids average 2000 pounds each so you need the proper equipment to unload them as well plus they have to be stored inside as if they sit outside, they attract moisture and damp pellets turn to mush in the bags which are usually 40 pounds per poly bag. Once they get soggy with moisture, they are not useable as a biomass stove needs it's fuel at or below 7% RM to combust.
/ Stove Pipe #32
All the outlets for wood pellets around here store the pallets of pellets (ha ha) outdoors, un-covered.
Must be a New England thing, or modern packaging.
I have three pallets under tarp....
/ Stove Pipe #33
I had a big 'ol Modine hanging ceiling heater in our garage in AK. Heat came from a hot water loop off our natural gas furnace. It must have been 100K BTU, at least. It would bring the garage to 70F in less than an hour.
The garage was only 20x30 and well insulated. Including an insulated door.
/ Stove Pipe #34
Keep in mind that Harmon is by far the most expensive solid fuel burning units on the market today and far as I know, none of them are corn biomass capable.
If corn biomass is important to you, then by all means... but I came to the conclusion that Harmon is one to consider from spending way more time and years at hearth.com than I've ever spent here, and hearing what the pellet burners there say.
That said, I'm a cordwood burner, I don't run pellet stoves. So I'm going on advice I've gathered from others' experience, albeit vast experience over many years, not my own.
In my opinion, Harmon's are pretty units but I'm not into pretty, I'm into functional and all of them basically do the same thing and that is rapid oxidation of a solid fuel source and produce heat and all of them must be at least 80% efficient or again they cannot be sold domestically.
Pretty and functional are not necessarily intertwined. Maybe they're pretty, maybe they're not... and maybe beauty is in the eye of the beholder. That's all irrelevant.
My conclusion that Harmons were one to consider came from watching the number of posts from the pellet heads, about various troubles they're having with many other brands, and several of them eventually upgrading from other brands to a Harmon. I don't think that cosmetics were their primary reason, nor did I ever say they were the only brand to buy, just the one I'd be shopping first among many.
I prefer not being tied to pellet supply issues, and so I run wood stoves, albeit multiple wood stoves at the same time, heating this huge old barn of a house. My wood fuel is free, and always available, but it cannot self-regulate day to night like a pellet stove can. But my cordwood stoves can run 30 - 40 hours on a single load, so if the OP is in a position where they're available to tend the thing at least once per day, it's worth consideration.
/ Stove Pipe #35
Like I said previously, with the cost of manufactured pellets today, they are almost cost prohibitive to operate unless you can buy pellets in truckload quantities which I have in the past. truckload quantity is usually 22 skids of pellets delivered on a tractor trailer and the skids average 2000 pounds each so you need the proper equipment to unload them as well plus they have to be stored inside as if they sit outside, they attract moisture and damp pellets turn to mush in the bags which are usually 40 pounds per poly bag. Once they get soggy with moisture, they are not useable as a biomass stove needs its fuel at or below 7% RM to combust.
I agree that no to low creosote production has something to do with operation and venting. Creosote is a result of incomplete combustion, aka smoke, and water. Pellet stoves do better than older wood stoves, but deposits can be a problem both from particular stoves designs and operation, and from the quality of the input pellets, e.g. water content and the particular properties of the biomass in the pellet. e.g. corn vs sawdust vs bark vs fiber.
Corn, due to its protein, aka amino acid, content and its typically relatively high water content, produces particularly corrosive combustion gases, requiring stainless steel pipe, and regular cleaning. I understand the appeal, but as I wrote above, the composition of the biomass for the pellet makes a difference.
All the best,
Peter
/ Stove Pipe #36
An observation:
As last year was the first winter season that the pellet stove ran 24/7 the entire heating year, and the warnings and information posted on this thread, I JUST NOW disassembled the 6 foot long, 4 inch dia., single wall galvanizedmetal flue pipe that connects the stove to the masonry chimney for inspection and cleaning.
What did I observe?
Perhaps 1/2 cup of fine dry fly ash, lightly adhered to the pipe inside..
Less than 1/4 cup of the same within the chimney thimble. All material dropped out with a light tapping of the pipe with a small stick. The thimble swept clean with a hand dust broom.
I used the shop vac to remove the small amount of ash at the first elbow from the stove at ground level. Observation of that section shows clean metal after.
The burn volume last season was about a ton and a half. Pellets are labeled "premium", not that I know what that describes.
After 30 plus years of cleaning pipes for the downstairs wood stove. I'm impressed and satisfied with the clean burn of this pellet stove. A Breckwell.
/ Stove Pipe #37
All pellet vent has a stainless steel inner liner, the only difference between venting approved for combusting corn versus combusting pellets only is the grade of stainless used. That's it.
In reality there is no difference between 'Premium' pellets and normal pellets. Most are produced from wood that is deemed not useable for anything else, like wood slash or recycled wood pallets for instance.
Myself, I use 6" pellet vent, 4 from the units to the outside with a 4-6 increaser with an open bottom I install a short piece of venting into with a removable cap abd I use that for a cleanout.
I completely take apart the venting every spring and pressure wash it inside and add Purple Power in a spray bottle prior to, to remove all traces of fly ash.
6" is better than 4" simply because 6" produces a better natural draft and helps the units extract the by products of combustion more efficiently. 6" is also more expensive than 4"
I run Duravent only, not Selkirk. I prefer the Duravent positive interlock.
and... the units get completely taken apart every spring and cleaned as well and I remove the induced draft fans, drive motors and clean and lubricate them as well. Remember all of them rely on mechanical means to control and maintain combustion. The internal mechanical components of any unit live in a dusty, somewhat abrasive atmosphere inside the cabinet so bearings and rotating components need to be maintained and lubricated.
Like I said, been doing this for 30 years now and I've already experienced most all the pitfalls of ownership. Replacement components are always expensive so much like a tractor, timely maintenance is paramount.
I also have extra burn pots for all of them and I remove the burn pots weekly and replace them with a cleaned one and I soak the burn pots in a bucket of water. That loosens any carbon buildup on them and allows me to remove it with a putty knife and / or a scotchbrite pad.
In my situation this year, propane is actually less expensive than biomass, consequently, the unit in the house will probably not get used at all. The pair in the shop will but sparingly because I also have propane fired in floor heat (PEX) in the shop.
/ Stove Pipe
There is much that I have learned from this thread and from my own research. For example, it never dawned on me that burring a kerosene or diesel heater would be the cause of so much condensation. After doing some pondering and discussing the issue with SWMBO, we have decided to go in an entirely different direction.
This year, since I wont actually be home much, I will use the kerosene heater when I need to work out there. The things that I'm afraid will be damaged due to the cold, we will move into one of the room with electric heat.
Once we have the funds saved up (I hate credit) we will purchase a large natural gas shop heater. I am hoping to install this by this time next year. At $1800, it is not something I can run out and purchase right now. Once we get the heater, we will plumb in the natural gas line. My house is pretty close to the shop where the gas line enters the house. It's about 30ft. That will be another expense as I have limited experience with installing gas lines and do not have the tooling to do it. I can however, dig the trench.
Once the natural gas heater is up and running, we will then shift our focus to insulation. Right now, the shop has a little insulation, if you can call it that. Its that thin layer of foam and plastic between the wood supports and the sheet metal. The roof also has this, but its all so thin and barely does anything. Pricing out insulation these days is mind boggling expensive! So, this will be done in sections when I can afford it, until the job is done.
We think that doing it this way, spending the money on something that we don't have to fuel, clean, worry about, etc is the way to go. It's expensive, but offers peace of mind.
I thank you all for the advise. You honestly saved me from doing something I'd later regret. This forum is amazing! I've learned so much here. Thank you all again!!
/ Stove Pipe #39
I'm sure there are variations of approved underground pipe for gas...
My last install required a pipe that was coated in a yellow plastic wrap over a almost tar like coating...
I was replacing with a permit 50 year old black iron that rusted out and found by the odor and sound of gas escaping...
/ Stove Pipe #40
If I had Natural gas available, burning kerosene or wood pellets would not even enter considerations.
CAT 312C EXCAVATOR (A58214)
CAT 312C EXCAVATOR...
2012 MACK CHU (PINNACLE) (A60736)
2012 MACK CHU...
IRTPL 10,000 LBS TWO POST LIFT (A58214)
IRTPL 10,000 LBS...
INGERSOLL RAND  G25 GENERATOR (A58216)
INGERSOLL RAND...
Year: 2017 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 101,691 Plate: Body Type... (A55853)
Year: 2017 Make...
1992 Talbert 70 Ton Lowboy Trailer with Removable Gooseneck (A61307)
1992 Talbert 70...
