Incompetent welder!
/ Incompetent welder! #1
orezok
Super Member
Mojave Desert, CA
Kubota B7800
I have a set of gauge wheels on my landscape rake that uses a 2" receiver for attachment. The top cylinder can exert a significant amount of force on the wheels if you're not careful and the attachment finally started to break and deform.
I flipped it over to look at the welds and fix it when I noticed that several of the welds were cracking and needed to be repaired. It's an inside corner vertical weld that is hard to reach so I had to use a die grinder to groove out the old weld.
After I get it all ground out and look at it, I think someone sure doesn't know how to weld.
...and then I remember that I fabricated the receiver attachment myself.
INCOMPETENT WELDER!
Added some stiffeners to transfer the load better.
/ Incompetent welder! #3
You should write yourself a strongly worded letter. In response to said letter you should send the author a case of beer to make amends.
/ Incompetent welder! #5
INCOMPETENT WELDER!
We need to see some pic's of that (for educational purposes only.....he..he!) :)
2018 CATERPILLAR 320 EXCAVATOR (A62129)
2018 CATERPILLAR...
Caterpillar 259D3 Compact Track Loader Skid Steer (A61572)
Caterpillar 259D3...
2023 Kubota Z412KW-48 Commercial Zero Turn Mower (A63689)
2023 Kubota...
2012 Gastron Boat w S/A Boat Trailer. (A61574)
2012 Gastron Boat...
2018 Jayco JayFlight 264BH (A62613)
2018 Jayco...
2005 BOBCAT 323J EXCAVATOR (A64279)
2005 BOBCAT 323J...
