Incompetent welder!
/ Incompetent welder! #1
orezok
Super Member
Mojave Desert, CA
Kubota B7800
I have a set of gauge wheels on my landscape rake that uses a 2" receiver for attachment. The top cylinder can exert a significant amount of force on the wheels if you're not careful and the attachment finally started to break and deform.
I flipped it over to look at the welds and fix it when I noticed that several of the welds were cracking and needed to be repaired. It's an inside corner vertical weld that is hard to reach so I had to use a die grinder to groove out the old weld.
After I get it all ground out and look at it, I think someone sure doesn't know how to weld.
...and then I remember that I fabricated the receiver attachment myself.
INCOMPETENT WELDER!
Added some stiffeners to transfer the load better.
/ Incompetent welder! #3
You should write yourself a strongly worded letter. In response to said letter you should send the author a case of beer to make amends.
/ Incompetent welder! #5
INCOMPETENT WELDER!
We need to see some pic's of that (for educational purposes only.....he..he!) :)
2020 Global R3 Air Street Sweeper (A56857)
2020 Global R3 Air...
YANMAR VIO35-6A EXCAVATOR (A63276)
YANMAR VIO35-6A...
Box of Transport Ratchet Straps (A59230)
Box of Transport...
UNUSED INDUSTRIAS AMERICA C10 10' FEEDER TROUGH (A60430)
UNUSED INDUSTRIAS...
2013 John Deere Hydraulic Grapple Tractor Attachment (A61572)
2013 John Deere...
UNVERFERTH 12R30" RIP STRIPPER (A63291)
UNVERFERTH 12R30"...
