Incompetent welder!
/ Incompetent welder! #1
orezok
Super Member
Mojave Desert, CA
Kubota B7800
I have a set of gauge wheels on my landscape rake that uses a 2" receiver for attachment. The top cylinder can exert a significant amount of force on the wheels if you're not careful and the attachment finally started to break and deform.
I flipped it over to look at the welds and fix it when I noticed that several of the welds were cracking and needed to be repaired. It's an inside corner vertical weld that is hard to reach so I had to use a die grinder to groove out the old weld.
After I get it all ground out and look at it, I think someone sure doesn't know how to weld.
...and then I remember that I fabricated the receiver attachment myself.
INCOMPETENT WELDER!
Added some stiffeners to transfer the load better.
/ Incompetent welder! #3
You should write yourself a strongly worded letter. In response to said letter you should send the author a case of beer to make amends.
/ Incompetent welder! #5
INCOMPETENT WELDER!
We need to see some pic's of that (for educational purposes only.....he..he!) :)
2019 HYUNDAI V12530152-AJS DRY VAN (A59912)
2019 HYUNDAI...
2014 ISUZU NPR 4X2 18FT BOX TRUCK (A59911)
2014 ISUZU NPR 4X2...
E-Z DUMPER T/A DUMP TRAILER (A63291)
E-Z DUMPER T/A...
2019 DITCH WITCH TOWABLE VACUUM TRAILER (A63276)
2019 DITCH WITCH...
2024 COLEMAN MINI BIKE (A58375)
2024 COLEMAN MINI...
2005 Butler pole trailer (A62679)
2005 Butler pole...
