Incompetent welder!
/ Incompetent welder! #1
orezok
Super Member
Mojave Desert, CA
Kubota B7800
I have a set of gauge wheels on my landscape rake that uses a 2" receiver for attachment. The top cylinder can exert a significant amount of force on the wheels if you're not careful and the attachment finally started to break and deform.
I flipped it over to look at the welds and fix it when I noticed that several of the welds were cracking and needed to be repaired. It's an inside corner vertical weld that is hard to reach so I had to use a die grinder to groove out the old weld.
After I get it all ground out and look at it, I think someone sure doesn't know how to weld.
...and then I remember that I fabricated the receiver attachment myself.
INCOMPETENT WELDER!
Added some stiffeners to transfer the load better.
/ Incompetent welder! #3
You should write yourself a strongly worded letter. In response to said letter you should send the author a case of beer to make amends.
/ Incompetent welder! #5
INCOMPETENT WELDER!
We need to see some pic's of that (for educational purposes only.....he..he!) :)
2022 Takeuchi TL12R2 (A60462)
2022 Takeuchi...
2008 CATERPILLAR D4K XL CRAWLER DOZER (A64279)
2008 CATERPILLAR...
2019 Dodge Durango SUV (A61574)
2019 Dodge Durango...
Chevy 2500 HD 4WD (A63689)
Chevy 2500 HD 4WD...
2017 TAKEUCHI TB290 EXCAVATOR (A64279)
2017 TAKEUCHI...
40ft Shipping Container (A64194)
40ft Shipping...
