Rotary Cutter I need help with bush hog blade
   / I need help with bush hog blade #11
chh said:
If they are tight/rusted enough that they won't break loose with a 3/4 and a cheater bar is is better to have them cut off with a torch and put in new bolts. I have read advise to replace the bolts every time the nut is taken off for safety reasons. You sure don't want to use a damage one because flying blades aren't much fun. I usually sharpen them with an angle grinder while they are on the machine.
The NUTS were remove last winter, thanks to a friend. That took him and a 5' piece of pipe to bust em loose.
I just came in from getting the bolts pushed out. My method did work. Drilled a hole in a piece of 2x4 and slid a 3/4" extension bar through the hole. 2by is used to hold the extension on top of the bolt so I could hit it with the sledge.. It took a 10 or 15 swing for each bolt but they are out and the blade(s) are off. Can't find one of the blades, but I'm sure its under the bushhog. Looking at the blade I took off, I think I'm just going to get new ones.
Wedge
2022 Carry-On 5'x8' Trailer (A53316)
2022 Carry-On...
2016 FORD FUSION SS (A60430)
2016 FORD FUSION...
2025 GPS Trailer (A56858)
2025 GPS Trailer...
2017 Toyota Tundra SR5 Ext. Cab Pickup Truck (A59230)
2017 Toyota Tundra...
2022 CATERPILLAR 242D3 SKID STEER (A60429)
2022 CATERPILLAR...
2019 BOBCAT T450 SKID STEER (A60429)
2019 BOBCAT T450...
