HVAC disconnect question
/ HVAC disconnect question #21
Here we go, over thinking again. The old adage KISS applies here!
/ HVAC disconnect question #22
Well, ive been doing commercial and industrial electrical for 35 years. All our motors have a fused disconnect. And all motor control panels have multiple fuse protection devices along with heaters . Breakers are always rated 125% over motor loads. Offer limited protection .
but i digress from OP. The states i work in require that we follow nameplate on device. For instance my AC unit has a nameplate that states minimum fuse size. I HAVE to use fuse. If label says minimum OCPD (over current protective device) then you can use a breaker. All this is superseded by whatever manufacturer requires. Most A/C Manufacturers install paperwork i used to read REQUIRED a fused disconnect, so it was never an issue.
/ HVAC disconnect question #23
I have had a number of corrections (from inspectors) due to the manufacturers label saying minimum fuse size, and then being required to install a fused disconnect to pass inspection.
If it states minimum OCPD (overcurrent protection device), then a breaker in the panel can be the protective device and non-fused cheap disconnect can be installed next to the HVAC unit.
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60460)
2019 International...
2011 FREIGHTLINER M2 (A60736)
2011 FREIGHTLINER...
1985 CADILLAC SEVILLE (A60736)
1985 CADILLAC...
Giyi GY-CWG72 Quick Attach Curved Wood Grabber (A60463)
Giyi GY-CWG72...
NEW HOLLAND T4.75 POWERSTAR TRACTOR (A62130)
NEW HOLLAND T4.75...
UNVERFERTH 330 - 19-INCH EXTENSION KIT FOR RIP-STRIP TOOLBAR PART # 63186G (A55315)
UNVERFERTH 330 -...
