HVAC disconnect question
/ HVAC disconnect question #21
Here we go, over thinking again. The old adage KISS applies here!
/ HVAC disconnect question #22
Well, ive been doing commercial and industrial electrical for 35 years. All our motors have a fused disconnect. And all motor control panels have multiple fuse protection devices along with heaters . Breakers are always rated 125% over motor loads. Offer limited protection .
but i digress from OP. The states i work in require that we follow nameplate on device. For instance my AC unit has a nameplate that states minimum fuse size. I HAVE to use fuse. If label says minimum OCPD (over current protective device) then you can use a breaker. All this is superseded by whatever manufacturer requires. Most A/C Manufacturers install paperwork i used to read REQUIRED a fused disconnect, so it was never an issue.
/ HVAC disconnect question #23
I have had a number of corrections (from inspectors) due to the manufacturers label saying minimum fuse size, and then being required to install a fused disconnect to pass inspection.
If it states minimum OCPD (overcurrent protection device), then a breaker in the panel can be the protective device and non-fused cheap disconnect can be installed next to the HVAC unit.
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A61307)
2006 Magnolia Dry...
2018 Jeep Grand Cherokee Trackhawk 4x4 SUV (A64557)
2018 Jeep Grand...
JOHN DEERE 5075M TRACTOR (A63291)
JOHN DEERE 5075M...
2014 UTILITY 53X102 DRY VAN TRAILER (A59914)
2014 UTILITY...
2005 GMC C5500 (A64127)
2005 GMC C5500...
2014 Freightliner M2 112 Tandem Dump (A62613)
2014 Freightliner...
