How to use a Grader Scraper
   / How to use a Grader Scraper #51
A section of chain link fence panel secured on all sides by pipe and stretched tight (think gate panel) makes an awesome final finish gravel smoother. Get a panel as wide as your road and drag it with a chain. Of course you have to man handle it into place when you change directions but it works very well.
I have used a heavy wood skid too. Add some weight in the back or front to tailor how much it digs in. Also hook the chain to the 3pt so you can change how the front of the skid digs in.
   / How to use a Grader Scraper #52
I think you are on to something here. One complaint I have with the landplane is it does not carry material from the highs and deposit in the lows as a box blade does. Nice that it separates the grass out too.
My old MF 30B skiploader gannon back board had a float option. The board was heavy and it lifted a few inches, enough to let a rock kick out instead of holding up the blade.
P.S.
I saw a guy with a water tank on one of these. It had a sprayer in front for dust control? Or material workability? And it added WEIGHT.
Anyway - thanks for sharing your modification. This is on my project list. (y)
   / How to use a Grader Scraper #53
After almost three years of "thinking about it", I finally purchased a Rankin GS-5 Grader Scraper (aka; Landplane) for my Kubota L2501.
Yes, it is a lot easier than trying to use the bucket or rear blade. However, it isn't quite as easy as I had anticipated. But maybe I am not using it correctly. So I was hoping I could get some "tips" here.
My primary use is for gravel on my driveway. Indeed, I just had a load of gravel delivered today and I am in the process of spreading and leveling it out. I purchased the device because I was of the understanding that, without hydraulic top and tilt, it's easier to use than a box blade. So, I went with this far more expensive option.
My understanding is that I want the implement level front to back so that both blades equally engage the material.
I thought that it was meant to be "dropped and dragged". But when I do that, I just load it up with material (like it's flowing over the sides). So I have been ever so slightly holding it up. But then, whenever the tractor goes over a bump or dip, the Grader Scraper goes down or up respectively....just like my rear blade does. Rankin says (in their instructions) that the blades are set down 1/4" from the factory....which they seem to be.
I do not want a crown on the road (so I don't cut it off in the winter when plowing with my rear blade) so I set one side higher than the other and have been attempting to work the material out to each side. Seems to be getting there, but it's taking a lot of passes (many dozens).
I am unsure which way the blades should run. I sort of assumed that they should be angled off to the side of the road. But, because my gravel road turns into pavement at the end, if I keep dragging it the same direction I then get a pile of gravel at that one end, on one side. So, after a dozen or so passes, I then tilt the implement the other way and go the other direction so I can drag the material away from the paved road.
I enjoy tractor time, but it just seems to be taking way, way, too long to work this short (less than 200') section of road.
Maybe I am expecting too much from the tool (or gravel for that matter), but I sure would appreciate suggestions on how to use this (supposedly simple) implement.
Thanks
A box blade and experience with it is hard to beat. For a fine surface refinisher use a Landscape rake. You can buy both for price of a Land plane.
   / How to use a Grader Scraper #54
When you say you had a load of gravel delivered - how did they deliver it? One pile you have to spread over the 200', several piles spaced out along the drive, or did they tail gate it so you have a roughly even layer the length of the drive ?
Trying to get a picture in my mind of what you are doing.
gg
A good gravel delivery should involve a spreading of gravel. If truck has access to area he should be able to spread as little as inch and thicker. You should only have minor raking to do.
I have a 1325 ft driveway and a two truck delivery of a total of 36 tons. The only scraping I do is the beginning of area unloading starts.
   / How to use a Grader Scraper #55
I got my bush hog 7ft landscape rake for $200 from a neighbor. When he asked if I wanted the rake for that amount I almost broke a finger trying to get the money out of my pocket fast enough. One of the best tools I got. Right now I'm trying my darndest to build a set of gauge wheels for it. I'm picking rocks off the property and maintaining the gravel road with it. And I have the 3 way gannon also
   / How to use a Grader Scraper #56
scootr, Please detail your gauge wheel build as you progress. I will follow "eagerly". I've got a woods 60" rake and I sure wish I had gauge wheels for it!! Would love to have some ideas on how to build a set. Thanks, Greg
   / How to use a Grader Scraper #57
   / How to use a Grader Scraper #58
You're putting 20 more yards onto a 200' section of road?!? You have way too much loose gravel, me thinks. You can't expect to easily smooth out a big bowl of mush. Post some pics for us.
What did you use for the bottom layer(s) ? I constructed my driveway with a well crowned/raised bed of sand (my local soil type), packed as well as my tractor tires would do under a fully loaded machine (heavy rear attachment, full bucket of material on front loader). Then a mixture of 3"-minus gravel and crushed concrete, whichever one was more conveniently available and affordable for me. I let the semi trucks and concrete trucks compact this for my during my home's construction (concrete trucks are the ultimate road compaction!). Only after this point did I start putting 3/4"-minus over top, and I really only have a few inches of it at most.
I was thinking the same thing. Lot of rock for a short drive. Unless it's really, really wide!! ;)
   / How to use a Grader Scraper #59
I didn't take any pictures, unfortunately, but I spent yesterday spreading 56 tonnes of 20mm quarry rubble over virgin loamy-sand to make a driveway and car park. I used my 3720 and land plane to spread it 150mm thick and reasonably smooth.
The driveway section was pre-spread with the dump truck, but the car park section had to be made from individual piles. I spent probably as much time dragging the land plane forward as pushing it in reverse. When I needed to get gravel into a corner or a low spot, I used the FEL bucket to transport it, but the land plane did most of the work. Sometimes it will carry too much material, so the 3PH needs to be 'worked' a bit. This is less of a problem on previously compacted rubble, hence I have just done a good enough job until the rubble gets packed down from use, then I will return and polish it nicely smooth with the same land plane.
I completed my driveway and and parking area the other day by renting a roller/vibratory compactor. Now it's pretty smooth (not quite as smooth as an asphalt road, but really close). Will see how long it lasts.
My notes on using the Landplane. These notes are based on what I have heard here as well as what I have learned using the implement. Since I have not used the scrafiers (yet), I have no comments about their use. These are MY notes and are really only intended for me to refer to. If others find them useful, then great. But they are not intended to be a tutorial in the operation of a Landplane as other peoples experiences undoubtedly are different (as clearly seen in this thread).
- Material type and moisture content is critical. Material with a lot of fines (for good compaction under the finish layer) tends to clump up when wet. It also can overflow the sides of the landplane if too much is grabbed at once. Whereas super loose and/or dry gravel (with minimal fines) just flows over the blades as would be expected. Too dry = lots of dust.
- A landplane is not a drop and drag implement. It requires constant monitoring and adjustment (feathering) of the three point height. I had the best "luck" using settings between 2 and 3 with just a slight change making a huge difference on the ground.
- Fresh (newly deposited) or lose material requires a higher setting (and more feathering) of the three point control, than does well compacted material.
- A landplane will move a significant amount of material around (if desired), but it doesn't spread it very well then. If material is in a pile, drag away small amounts at a time onto an already somewhat leveled surface.
- Fix imperfections as you find them otherwise they will continue to screw with you (i.e.; cause the tractor to pitch one way which causes the implement to pitch the other way, either leaving a pile or dip)
- Be super cautions about pushing material with it as the three point is not designed for these forces.
- Do not overwork the gravel. Moving the gravel around too much causes the fines to drop out leaving the courser material at the top. The course material doesn't compact (or stay compacted) well.
- While the instructions say to set it to level (front to back), it seems to work best with the front slightly raised.
- Can go either way with the implement, but I prefer to drag with the blades angled toward the center of the road (i.e.; drive on the right side of the road) as much as possible.
- Go slow but steady.
- Drag away from (not towards) pavement or places you don't want to deposit material. Otherwise you wind up with a pile at the transition that then has to be leveled out.
- Take your time, be patient and enjoy the "seat time".
Thank you to all who have contributed to my journey of getting to know my landplane.
SKID STEER ATTACHMENT TILLER (A58214)
SKID STEER...
2005 FORD F-450XL SUPER DUTY DUMP TRUCK (A52707)
2005 FORD F-450XL...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
2022 Brush Wolf 7800-HF Skid Steer Brush Cutter (A56436)
2022 Brush Wolf...
*Selling at Royal Auction Zephyrhills, FL Location* (A59228)
*Selling at Royal...
2020 Chevrolet Silverado 1500 (A55315)
2020 Chevrolet...
