300UGUY
Super Member
I wouldn't worry too much. The idea of plywood and screws sounds like a good fix.
It would be nearly impossible to do it on both sides unless you took off the side metal walls, correct?
Could you be a little more specifc as to which 2x you are referring to (the bottom chord that is split?).
Yes the horizontal 2x8? install another one next to this, crown up. Jack up your old 2x8s to line up, some construction adhesive wouldn't hurt either. Lots of screws to pull it tight. There shouldn't be much of a load there with the end wall post's so close. Are you installing a metal ceiling and insulation?
Dave
