How I attached hooks to bucket--photo
   / How I attached hooks to bucket--photo #12
sixdogs said:
Thanks and after my time at FT Polk in the late '60's I came to love most things Cajun--other than Ft Polk and most of the water type snakes. You guys hunt any birds down there like quail or ?.
What a coincidence. I was in Ft. Polk in the late 60's too, and am from Ohio, sort of.
Every bucket hook thread gets a lot of action, because there's 57 ways to attach them. Probably 55 of the ways are just fine.
   / How I attached hooks to bucket--photo #13
I had a weld on hook welded on my bucket and it broke!!! I replaced it with a piece of 1" steel welded down flat on the top of the buket, then torched a hole through the steel plate and the bucket, then inserted a 2 5/16" ball. Now I can move the gooseneck around very easy and still wrap a chain around the ball.
   / How I attached hooks to bucket--photo #14
Will a 3/8 size grab hook accommodate both 3/8 and 5/16 chain??
   / How I attached hooks to bucket--photo #15
Yes. 3/8" hooks will work with 5/16" chain. Usually will work with 1/4" to 1/2". Almost all 5/16" hooks will work with 3/16" to 3/8" chain also.
   / How I attached hooks to bucket--photo #17
dfkrug said:
Wow, $189 to avoid a little welding!?
Slick setup, but that's exactly what I thought. It appears as if they use the 3/8" weld on hooks (can't tell if they're grade 40 or 70, but it wouldn't make any difference on the little tractor it's made for) that cost $3 or $4 each and maybe another $10 in materials or so. I guess you're paying for their, admittedly, slick design work.
   / How I attached hooks to bucket--photo #18
here is a universal mounting i made
   / How I attached hooks to bucket--photo #20
One thing I will add because I haven't seen it in this post is to preheat your hooks before you weld them. This prevents cracking as the weld cools. I usually use a map or propane torch for a few minutes.
1408 (A57192)
1408 (A57192)
2020 CATERPILLAR 299D3 XE SKID STEER (A60429)
2020 CATERPILLAR...
PNEUMATIC GREASE UNIT (A58214)
PNEUMATIC GREASE...
2002 TOYOTA 7FDKU40 FORKLIFT (A57880)
2002 TOYOTA...
2013 JOHN DEERE 772G MOTORGRADER (A60429)
2013 JOHN DEERE...
GEARMATIC WINCH (A58214)
GEARMATIC WINCH...
