Bolt-on hooks & D-rings on a JD compact with a HD bucket?
   / Bolt-on hooks & D-rings on a JD compact with a HD bucket? #1
lostcause
Veteran Member
Maine
I've got a 3039R with the HD bucket (removable cutting edge). The top plate on these buckets has a second layer of steel welded to the bottom lip - looks like the two plates are about 1" apart. If you look on Ebay or Amazon, these pre-made bolt on plates are all over the place for $30 for the L/R side pair with free shipping - there's also a wider center one with 2 hooks, 2 rings, and a 2" receiver for $40. They seem to be meant for the single layer steel buckets, but i'm thinking i can just drill through both layers and put a sleeve in so I can tighten the bolts without crushing the two layers, causing them to eventually loosen up. Just curious if anyone else has tried these? wondering if the bent down flange will interfere with the weld to the bottom plate and require trimming? Still seems like it would be worth the effort compared to the initial cost.
   / Bolt-on hooks & D-rings on a JD compact with a HD bucket? #2
I got my hooks from Home - BoltOnHooks LLC. They were a little more expensive than Amazon or eBay but well thought out and custom for my tractor and loader. Check out the options. Oh yeah, they're real people and will interact with you.
   / Bolt-on hooks & D-rings on a JD compact with a HD bucket? #3
You can’t go wrong with Ken’s bolt on hooks. It’s the first thing I did to my tractor. Easy enough to install and tough as all get-out.
LOT OF CHICKEN EQ. NEST, BROADER & FEEDER (A58374)
LOT OF CHICKEN EQ...
(2) LP GAS TANKS (A58374)
(2) LP GAS TANKS...
Toro Groundsmaster 3500-D Sidewinder 3 Deck Rotary Commercial Mower (A56857)
Toro Groundsmaster...
excavator trenching bucket- one bucket per lot (A56435)
excavator...
Miller Bobcat Welder/Generator AC/DC Welder, 1 Phase & 3 Phase Generator, S/N M0321574R, Kohler Gas (A59076)
Miller Bobcat...
BUNDLE OF 4" - 6" X 12' BUILDING PURLIN (A54757)
BUNDLE OF 4" - 6"...
