How I attached hooks to bucket--photo
   / How I attached hooks to bucket--photo #21
I thank the O/P for starting this topic.
It got me re-thinking how I do what I do.
I had a 400+ mile drive yesterday, so had time to mull things over.
My most used buckets have 2 loops welded on, quite close to where the SS plate hooks up, I have a center chain hook on most of them too.
What I plan to do is to use anchor shackles in the loops and will keep a couple of lengths of chain for lifting from BOTH points.
I might put grab hooks onto anchor shackles, not sure of the EXACT details of how I will do this, but I DO want to go from single point lifting to two point lifting.
That side to side pendulum effect has always bothered me, just never enough to DO anything about it - it is time to DO something about it (-:
Side swinging a) shouldn't happen when lifting from 2 points b) if it does happen the chain on the side the load moves away from SHOULD help to restore stability.
With a plate welded on first and the hook welded to the plate and centered over each of the loader arms, I have never had a stability problem. Remember I hook a chain between the bucket hooks and then hook a small grab clevis chain in the center of that chain.
I only pick up with one chain and regularly pick up 2,000 to 3,000 lb loads of awkward equipment..
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2005 Peterbilt 357 Truck (A55973)
2005 Peterbilt 357...
2003 International 9200I (A53317)
2003 International...
2021 KUBOTA SVL75-2 SKID STEER (A60429)
2021 KUBOTA...
2019 ALLMAND MAXI-POWER 25 GENERATOR (A58214)
2019 ALLMAND...
