How do you keep rotary mower blades from binding?
   / How do you keep rotary mower blades from binding? #11
</font><font color="blue" class="small">( That's why I said, "Put something under the mower..." !! )</font>
John,
Guess you should've said..."Something other than yourself!" /forums/images/graemlins/shocked.gif /forums/images/graemlins/grin.gif
   / How do you keep rotary mower blades from binding? #12
</font><font color="blue" class="small">( Guess you should've said..."Something other than yourself!" )</font>
/forums/images/graemlins/grin.gif you got that right Gary! John
   / How do you keep rotary mower blades from binding? #13
</font><font color="blue" class="small">( OK, OK! But the last time I did that the darn thing fell on me and the missus had to come out and lift it off of me. /forums/images/graemlins/blush.gif )</font>
You and me would trust our wives to do that job, but many wouldn't want the wife anywhere near the tractor in in such a compromised position! /forums/images/graemlins/shocked.gif
   / How do you keep rotary mower blades from binding? #14
Life insurance is supposed to make us rest easier?
   / How do you keep rotary mower blades from binding? #15
I can hear it now - "the last thing he said was no, no, not THAT lever!"
Well, I finally got time to look into my blade binding problem. I flipped the mower over and discovered that the stump jumper is bent on one end. this is causing just enough deflection to make the blade stick if it is moving slow. I guess the short term solution is to keep my RPMs up, but there is a definite wear arc on the stump jumper where the blade has been hitting it and I am concerned that it may have weakened it to a point where it may fail if I spin it up too high.
Anyone replaced/repaired one of these?
   / How do you keep rotary mower blades from binding? #17
<font color="blue">I can hear it now - "the last thing he said was no, no, not THAT lever!" </font>
A neighbor actually lost life doing a blade sharpening job on his bruh hog. His adolescent son accidentally bumped the tractor starter while Daddy was under the machine. PTO lever was engaged and Cut the top of his head off. 15 years later and the Son is still not mentally stable.-Ken Sweet
Sweet Farm Equipment LLC *Over 30 Used Cultipackers in stock, starting at $295 for a 3 ft single*
   / How do you keep rotary mower blades from binding? #18
HUmmm you might take it off and heat it enough to remove the bend. i have never taken a stump jumper off but it doesnt look that hard. and you said it was old and brand not known so parts might be hard to find.
Ken you will make me have nightmares now! /forums/images/graemlins/shocked.gif
We have a machine shop in the facility where I work. So I might just pull it off and have them make me a new one (they do personal stuff all the time, brake rotors, flywheels, etc...). I pulled both blades off (had to use an impact wrench) and took them in. Had one of the QC inspectors do a Dye Penetrant test on them and one has a crack that runs about 3/8 of an inch in from the leading edge of the blade about 2 inches from the blade tip so it looks like I'm gonna have to replace the blades too.
Kinda reminds me of the story where the an old guy was using an axe that once belonged to Abraham Lincoln, but since then it had 3 new heads and 5 new handles.
Kevin
   / How do you keep rotary mower blades from binding? #20
wow gettin pretty high tech there, dye checking the blades and all! tho about the stumpjumper thats gona be pretty hard to make, it would be alot easier for them to just straighten out the original one, im a machinist and i know myself i would probably just straighten out and weld up the old one before attempting to make a new one
40ft T/A Gooseneck Flatbed Equipment Trailer (A55851)
40ft T/A Gooseneck...
New/Unused 110V Diesel Pump with 50ft Hose (A57454)
New/Unused 110V...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A56436)
Michelin CARGOXBIB...
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A58214)
GRID SHAPED BUCKET...
(1) HD 24ft Free Standing Corral Panel (A57453)
(1) HD 24ft Free...
20ft Jumper Cables (A57454)
20ft Jumper Cables...
