How can a tractor overheat on the coldest day of the decade?
   / How can a tractor overheat on the coldest day of the decade? #11
Saw TX, freeze and knew exactly what happened. Amazing how loopholes and corner cutting shows its ugly head when things get a bit abnormal. Up here you would never find water in a radiator or a shallow water pipe going into someone’s house. I grew up in east tx and only remember 1 time we got snow.
Got that right. You can't hire a plumber or buy a plumbing fixture or a piece of copper pipe to save your life from Central Texas southward right now. Our houses are definitely not built for that kind of cold.
You probably also remember that you can lay a pipe on the ground, sprinkle some dust on top and it won't freeze -- in an ordinary winter!
   / How can a tractor overheat on the coldest day of the decade? #13
Do tractors have thermostats? they do go bad and you will defiantly
over heat!
on anti-freeze I mix for -50 degrees so never have a problem with
radiator also change hoses every 5 years with new anti-freeze
willy
Poly Fuel Tank with Electric Pump (A55851)
Poly Fuel Tank...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2000 Volvo Semi (A59814)
2000 Volvo Semi...
Kubota U55-4 (A57148)
2018 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A58017)
2018 INTERNATIONAL...
2010 KMC 3376 Peanut Combine (A56438)
2010 KMC 3376...
