How can a tractor overheat on the coldest day of the decade?
   / How can a tractor overheat on the coldest day of the decade? #11
Saw TX, freeze and knew exactly what happened. Amazing how loopholes and corner cutting shows its ugly head when things get a bit abnormal. Up here you would never find water in a radiator or a shallow water pipe going into someone’s house. I grew up in east tx and only remember 1 time we got snow.
Got that right. You can't hire a plumber or buy a plumbing fixture or a piece of copper pipe to save your life from Central Texas southward right now. Our houses are definitely not built for that kind of cold.
You probably also remember that you can lay a pipe on the ground, sprinkle some dust on top and it won't freeze -- in an ordinary winter!
   / How can a tractor overheat on the coldest day of the decade? #13
Do tractors have thermostats? they do go bad and you will defiantly
over heat!
on anti-freeze I mix for -50 degrees so never have a problem with
radiator also change hoses every 5 years with new anti-freeze
willy
UNUSED Heavy Duty Ratchet Strap Set (A53117)
UNUSED Heavy Duty...
2016 PETERBILT PB337 FLATBED TRUCK (A52706)
2016 PETERBILT...
2015 Ford F-450 9ft Utility Flatbed Truck (A55852)
2015 Ford F-450...
2025 JMR 78in Dual Cylinder Grapple Skid Steer Attachment (A53421)
2025 JMR 78in Dual...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
UNUSED FUTURE 350 HYD EXCAVATOR BREAKER HAMMER (A57193)
UNUSED FUTURE 350...
